Results 1 to 10 of 11
Thread: Dual Monitor DVD/DIVX Problem
    Mar 2004
    Has anyone ever tried to play DVD's or DIVX's on multiple monitors? I am trying with a lilliput hooked up to the VGA and a portable DVD player with an Aux input hooked to the RCA port on my EPIA MII10000.
    Both screens mimic each other up the point where I show a video. The RCA jack shows the movie OK, but the lilliput shows a black screen where the video is playing. It doesn't matter if the video is full screen or windowed, but when the video is windowed, all of the desktop behind the video shows up as normal on both screens, but the lilliput shows a video window that is just black.
    Has anyone else seen this??
    Thanks,
    Greg.
    Lilliput 7" w/TS
    EPIA MII 10K
    120W DC/DC
    ITPS
    BU-303 USB GPS
    MobileBlackBox USB FM Transmitter
    Toshibsa 60G HD
    Addonics USB DVD/CDRW
    Routis 2004
    Mappoint 2004
    Ordered: Proscan OBDII - PC Interface
    Maximum Bitrate dodgetimes2's Avatar
    MI
    I have a dual monitor set-up on my inhouse PC. I have the same issue you have. I can only play videos (or other graphics intensive apps) on one monitor at a time. I think it's something to do with DirectX. I say this because I use UltraMon to let me have separate wallpapers and screensavers and I can only run 1 screensaver at a time that uses DirectX. For example, I have the SereneScreen (3D aquarium that uses DirectX) running on one monitor and starfield simulation (non-DirectX) on the other monitor. If I try to run the SereneScreen on both it won't let me. I think this is just a software limitation, not a hardware problem.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Mar 2004
    Graphics-intensive applications sometimes have issues with multiple moniters (I run a dual moniter setup at home). I would recommend trying different video playes. In my experience, VLC player has handled it quite well.
    The other thing to try (assuming you have a nvidia card), is the video overlay feature. Check it out, it might do what you want.
    May 2004
    Dallas
    I had this problem a long time ago with a Geforce 4 card by Nvidia. it would play fine on my monitor, yet if i put a movie on, it would display fine on my tv and nothing but black on my monitor. eventially i fixed it with an Nvidia utility by setting my 2nd display as the main display and using my monitor as a second display, or something to that effect. It took many hours of searching msg boards to find out what to do. I wish you louck.
    Variable Bitrate Pokey's Avatar
    Tampa, Florida
    Make sure your display properties are set up correctly, you have an option where you can have two of the same or seperate.
    Dual Lilliput's 70NP/C/T
    Syntax SV266AD KT266A
    AMD Athlon XP 2000
    Viking 256MB DDR
    D-Link Wireless 802.11B
    Seagate 120GB
    OrbitMicro 250W DC/DC converter
    SII Wireless Audio Link
    Digimoto OBD-II
    Earthmate GPS
    BU-303 USB GPS
    D-Link Bluetooth
    Sep 2003
    Wilkes Barre, Pa
    Check out the UltraMon software.. It will let you mirror you monitors..
    http://www.realtimesoft.com/ultramon/
    http://www.realtimesoft.com/ultramon/tour/mirroring.asp
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Basically it means your card is only capable of a single video overlay. It's very rare to have a video card that'll display overlay video on more than one screen, even if it is mirrored.
    I have a card that supports two video overlays that I use with video editing that originally cost me around $350. I have no idea if it's come down in cost since then.
    Basically you're stuck with video off one display in your case, no matter what you do, probably unless you got a seperate video card for each output.
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    OVERLAY
    If you turn off hardware acceleration overlay wont be used
  1. Dual Battery Woes
    By BigRedBee in forum Power Supplies
    Last Post: 11-17-2004, 05:52 PM
  2. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  3. power on problem ??? help please anyone
    By Pingo1969 in forum Power Supplies
    Last Post: 04-07-2004, 08:47 AM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  5. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
