Results 1 to 3 of 3
Thread: Convert D-link to serial?
    Constant Bitrate NotchbackVW's Avatar
    Jan 2004
    UK
    Looking for a way around problem with D-link when resuming from hibirnation due to XP not reloading USB drivers succsesfully. Would it make any difference at all if we were able to convert the d-link to a serial connection? I am not sure if it would still act as a usb device and need the drivers or not. Anyone know?
    Any one tried this? can it bee done and would it fix the problems.
    After a some searching found this cable that nearly does it. Anyone know of a connector to do it in one, without hacking?
    http://www.mutek.co.uk/acatalog/USB_...onverters.html
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    You can't do it.....easily
    Jan 2004
    UK
    thought that me be the case. As found no cables to do it.
    Loads to make a USB a setial port but not the other way round. Thanks
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  3. Convert 1.5v, 3v, or 5v to serial signal
    By god_of_cpu in forum General Hardware Discussion
    Last Post: 03-11-2004, 02:14 PM
  4. USB to serial
    By Sleeka in forum General Hardware Discussion
    Last Post: 12-24-2002, 04:55 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
