Results 1 to 9 of 9
Thread: Mounting Direction of Mobo
    New York
    From the posts and pictures I've seen, just about everyone has their mobo mounted differently. I'd like to know whether a vertical mount will be perfectly safe (aka, like the way a Mobo is installd on a Tower).
    But more importantly, I'm refering to the weight of the CPU Cooling unit. Going over bumpy roads at 60, or even at 30 puts, imo, high stress on the pcb and socket. Anyone have any problems yet like this with this type of mount???
    If not, how big is the cooling unit, and if yes, what kinda damage did u receive. thx.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    If you use a regular ITX m/b with a large pentium/athalon heatsink then I think the mass of the heatsink could crack the processor or damage the m/b in extreme circumstances. And could no matter the orientation. The lightweight heatsinks on EPIA mini-ITX m/b should not have a problem.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    ...what he said. Just use common sense.
    New York
    ITX, hmm, how bout a full fledged ATX mobo
    But I like what you said about the Lightweight heatsink! Thats defiitely the trick to a sucesfull setup. Gonna go search for 'em now. Thats definiely the trick. If you happen to know a link for a good one, something that'll cool like a 2600+ AMD,post it up. Thx.
    mark
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Yup, you'd have even more problems with ATX format. The key is to get a low profile heatsink with a fast fan.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    I got the speeze low profile copper heatsink from Newegg. On the bench my Athlon-M 2600+ is running at 2ghz and 31C (at least according to the m/b).
    Seems to be cooling the CPU pretty effectively.
    http://www.newegg.com/app/ViewProduc...150-029&depa=0
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    Quote Originally Posted by pip
    That's a nice find. Gonna have remember that for my install. My only concern is it doesn't seem to be rated for a processor with your speed (or one that I want to go with).
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    I have the VIA MII 10000 and have noticed that the heatsink will pop off if a slight force is applied, but since it has springs holding it on it should pop back on. The only way I would not mount it is inverted since over time I can see the heatsink pop'ing off with the bumps in the road every now and then.
    Mar 2002
    Austin, Texas
    Wouldn't it have to be a pretty good jolt in order to pop off an ATX heatsink/fan. The ones that I have put on lately have all required a good bit of force in order to lock them down. I think as long as the "hold down bracket" is vertical it will help absorb more impact than horizontal.
    Derek
  1. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 09:24 PM
  2. mounting a miniITX mobo
    By lummox in forum General Hardware Discussion
    Last Post: 02-11-2004, 05:27 PM
  3. Properly grounding mobo
    By BMp3W in forum General Hardware Discussion
    Last Post: 11-17-2002, 10:50 AM
  4. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 06:40 PM
  5. hardware woes - just venting!
    By magnetik in forum Off Topic
    Last Post: 05-21-2002, 04:31 AM
