Results 1 to 6 of 6
Thread: Matsu****a SR-8185-C (Apple) DVD and Allmac adapter wiring?
    VENDOR - SpatialMinds millec's Avatar
    Dec 2002
    Mt. Vernon, WA
    In this post a great description of how to wire up a Matsu****a sr-8185-c slot load DVD/CD drive using the adapter available at Allmac.com.
    Apple DVD (Matsu****a) and Allmac adapter wiring
    See 6th post down the page.
    When the post was made, I ran out and bought the drive, and the adapter. A year later I am finally getting around to doing the install and all the links are dead. Does anyone have those photos, or extremely verbose <grin> instructions on how to get this thing wired up?
    I would love to get this thing in my car this weekend
    Thanks,
    --Craig
    Dec 2002
    Mt. Vernon, WA
    How do I attach power?
    Maybe this photo will help. I am pretty sure some of you have done this before. Could you verify what I have done, and make some suggestions on how I can hook up power to the drive?
    Thanks.
    Low Bitrate Linus's Avatar
    Oct 2001
    I got my 8184's and 8187 to work without bending pin 30. Solder the power onto one of the little black boxes on the left (positive to the + sign, ground below).
    Dec 2002
    Mt. Vernon, WA
    Thanks. That is pretty easy.
    Should I solder 5v or 12v?
    What about a ground wire?
    My pin had to be bent because my IDE connector had the hole filled. It was the only way to get it to go on without buying a new cable. Should be benign though. :-)
    Thanks again for the help.
    --Craig
    Oct 2001
    Quote Originally Posted by millec
    5V goes to the plus side of one of those little black chips, GRND goes to the other.
    Dec 2002
    Mt. Vernon, WA
    Quote Originally Posted by Linus
    Thanks for the help, I really do appreciate it.
    ROFL... Unfortunately, both little black chip (c2 and c3) have a + sign on them (see photo above in thread). There is a Plus sign adjacent to the c4 socket / silver grounding plate. I am guessing that c2 is positive and c3 is negative with the attached silver plate grounding via a screw to the DVD chassis.
    At least I know it is 5v now. I guess I have a 50 50 chance o making it work. I just don't want to fry it by experimenting.
    --Craig
  1. DVD drive adapter question
    By meddler in forum General Hardware Discussion
    Last Post: 11-21-2003, 06:50 PM
  2. Quest For an imac dvd adapter
    By GuRuGoD in forum General Hardware Discussion
    Last Post: 11-19-2002, 09:45 AM
