Results 1 to 10 of 18
Thread: HDD mounted upside down?
    May 2004
    okay, i've searched this and all i found is what i knew before - you can mount an HDD horizontally or vertically....
    but what about upside down? ie horizontally, but with the bottom facing up.... what i know about hard drives tells me that it would be fine, but thought i'd check first.
    and because you are all probably wondering "why the hell would you want to mount it upside down" - i bought a nice looking HDD cooling attachment that fits on the underside of the drive, and want it visible through my perspex window in the glovebox install if possible
    cheers
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    There actually is a thread about mounting HDDs upside down. Many people chimed in and said "huh, my hard drive is upside down??"
    As far as I know there is no problem with doing that. My hard drive is mounted upside down with no problems. But I haven't put it in the car yet. But functioning as a desktop, it works flawlessly.
    EDIT: Since you said you did a search, here is a freebie. I won't blow the search whistle, but I just put in HDD upside down.
    OK to mount hard drive upside down?
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    I got it upside down in my VW Jetta and it works just fine. It's just mounted to a hard surface with screws and even on hard bumps I have no problems.
    Mine needs to be updated.
    May 2004
    cheers lads
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    turned mine upside down and shook it to simulate road...eeeeh lockup
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Upside down has the same problem as mounting like normal. Modern hard drives have multiple platters so there is a chance the head from on platter will hit the other.
    Also shaking a hard drive well runing will definitly cause problems. In a car your only talking about hiting small bumps which the shocks/springs mostly take care of. With you hand you can actualy move that hard drive alot further than normal use in a car would ever move it.
    Mounting the drive on its side seems the best as that counters most movement from the car unless of corse you you get tboned and in that case the hard drive is the least of the wories.
    Elsewhere
    Quote Originally Posted by hcker2000
    There is no conclusive evedence of this whatsoever and it's been discussed at great lengths by people who are experts in the field.
    If you want to talk theories.... If your hard drive were mounted vertically, the lumps and bumps of normal driving would cause the heads to move up and down against the movement dictated when the drive is accessed, burning out the motor for the armature, rendereing the drive useless.
    Damn, I wish this pointless debate would die.
    How about the Wiki?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by DarquePervert
    Yup
    TruckinMP3
    Read the FAQ!
    Apr 2005
    Ireland
    And everything became solid-state. Or have a HUUUUGE wireless hub, and boot from LAN
    Mar 2005
    NY
    its a drive. it spins...very fast. whether you mount it left, right, upside down, verticla, inside out, mechanically speaking, it will break under jarring conditions. Shock mount the sucker and be done with it. I am fortunate enough to be using a very thing and rigid laptop, which i hope will be well shock mounted depending on where i put it. Un.less you're using solid state to boot up, which i may ater consider, its not worth it to not spend the $5 for spings and tools and hardware.
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
  1. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  2. Can a TM-701L housing be mounted upside down?
    By briang in forum LCD/Display
    Last Post: 03-15-2004, 04:47 PM
  3. Slimeline HDD -> IDE Adapter HELP!!
    By sq_geek in forum Classified Archive
    Last Post: 09-20-2003, 10:55 AM
  4. laptop hdd in desktop
    By slackingoff in forum General Hardware Discussion
    Last Post: 08-11-2003, 10:22 AM
  5. Shock mounts for case or HDD?
    By gork in forum General Hardware Discussion
    Last Post: 08-06-2003, 10:31 PM
