1. Look for an adaptor for the connector
2. Don't know, but if it came like that, leave well enough alone.
3. Don't have much experience with a bezel... translates:???, but I think maybe you could find a tutorial on google or something.
CarPC
VIA Nehemiah M10000, 256MB RAM, 40GB HDD
100W DC PS /w ITPS, TV tuner, Slim Slot-Load DVD
GPS, Streets and Trips 2004, Rearview Camera
Bluetooth, 802.11b & CDMA 1X
In-dash 7in Lilliput Touchscreen
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Looks like 50pin SCSI to me. Have to run it on a SCSI card. From what I can find they don't make an adapter to convert an SCSI device to IDE only the other way around. Have to solder on your own power connection too looks like.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
A quick search for "mac slim slot dvd" brought up tons of great threads about this, particularly this one:
Where to find the CORRECT laptop CDR/DVD to Desktop IDE Adapters
The adapters are getting hard to find, as allmac.com (the former supplier) doesn't have their parts catalog online anymore. But once you have the adapter, it's pretty simple - cut the tab off the IDE connector you want to use and plug it into the leftmost 40 pins of the adapter (as it's shown in the picture you attached). It isn't SCSI; the extra 10 pins are for power (which you can solder directly to the adapter, as shown in your pic) and audio (which you can do digitally over the IDE).
Seriously, try searching next time.
Thanks worked great
CarPC
