Results 1 to 10 of 15
Thread: Harddrive mounting idea..
    Jun 2003
    Memphis - TN
    I have attached an image of my harddrive mounting idea to help reduce shock. Comments?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Looks creative, but something like that might be more risk to your hard drive than normal shock. Not sure though, but I think i a lot of people get by without shock protection.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Here's my idea...
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    The springs will make the shock worse. However, replace the the springs with rubber or a dense foam then they would act as dampers to reduce shock and vibration.
    however you mount it, it cannot have a hard end of travel stop. Move the drive in all directions, if it hits a hard stop it's no good. The screws will slap around in the holes causing shock worse than the original acceleration.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by pip
    Exactly what I did. Been fine for nearly 5 years.
    Jun 2003
    Memphis - TN
    the slapping of the spring will depend on the spring rates of the springs
    If I use really stiff springs with rubber bumpers, there will be no "Slapping".
    That plate with the holes in it that heve the springs on either side- What happens when the screws start banging the sides of the holes? You can't make the holes too small or it will bind, so there will be play. I vote for the foam too.
    Jun 2003
    Memphis - TN
    u guys using foam dont worry about heat issues?
    pip
    pip is offline
    Mar 2004
    Parker, CO
    As long as you only use small rubber/foam pads and don't encase the drive there shouldn't be a problem. Encasing it in foam/rubber would kill the drive rather quickly.
  1. A question about mounting a flexible keyboard
    By Rudical in forum Input Devices
    Last Post: 08-05-2003, 09:54 PM
  2. Mounting Idea
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 05-12-2003, 10:32 PM
  3. Methods of mounting?
    By MP3DUB in forum General Hardware Discussion
    Last Post: 10-01-2002, 05:40 PM
  4. tracking idea
    By accord in forum GPS
    Last Post: 08-20-2002, 06:20 PM
  5. good idea for remote mounting of CD/DVD/HD
    By mprover in forum General Hardware Discussion
    Last Post: 08-10-2001, 01:49 AM
