Results 1 to 5 of 5
Thread: ASTEC POWER SUPPLY FROM MPJA
    Jun 2000
    ca
    Post ASTEC POWER SUPPLY FROM MPJA
    Hi All,
    Has anyone on the list tried to use the power supply found at http://www.mpja.com/product.asp?product=4786+PS made by Astec and sold bt MPJA. If someone out there is using it, please let me know. I can't seem to get it to output the proper voltages. Any help would be greatly appreciated.
    Thanx
    Mike
    moahdib's Avatar
    Jul 2000
    Post
    I got mine to work but i blew it the first time i tried to run my mobo with it. Not enough output..anyway i found lots of info at www.mattman.com he uses the same power supply and has a manual you see. that might help you.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Jun 2000
    ca
    Post
    Great, thanx for the help.
    Mike
    Jul 2000
    Lightbulb
    I bought this ASTEC PS and blew it. I was just the 6.2v zener I replaced it and retested the supply worked fine until i plugged it into my car. the problem I found is that the neg. output is floating leaving (i think) 6v between input gound and output ground.
    If you don't need a common ground then the supply is great, it has lots of current for such a small package.
    moahdib's Avatar
    Jul 2000
    Post
    i blew mine too hehe
    My TL CarPC ver2
