Results 1 to 4 of 4
Thread: Hot car = no boot?
    Feb 2004
    Hot car = no boot?
    I've had my VIA EPIA-M Motherboard in a C134 case running for a few months with no problem, but now that the weather is getting hot and my car is sitting out in the parking lot during work I've begun noticing that sometimes the machine won't boot. If I try to start it up right after I've gotten into the car in the afternoon the power will come on but the machine will not actually start booting. After I turn it off and turn it back on it will start up just fine and come out of hibernation. When the car is cool the box will also start up just fine. Has anyone else had this same problem, and if so what did you do about it?
    May 2004
    Just a guess since I don't have a VIA EPIA-M board, but most modern PC motherboards have built-in temperature sensors (commonly referred to the CPU and case temperature). BIOS's are usually very liberal on determining if a system will boot-up at a certain temperature. The act of opening your car door after it has been sealed and in the sun will drop the temperature considerably.
    There's almost no way around this problem other than finding a cool airflow to your C134 case while you're away. So I myself am not sure what else to recommend other than telling the BIOS *not* to automatically shut the system off when the temperature is over a certain range provided that the system cools down quickly after you boot it up.
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Out of curiousity, where is your system mounted in the vehicle? Dash? Trunk? What efforts have you made to cool it so far?
    It's getting to be summer and I have similar worries with the system I want to put in.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Feb 2004
    Currently its sitting behind the driver's seat. Like I said, I'm having no problems with it once the car is started and cooled down. I'm not doing anything special to cool it.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. off the wall ideas
    By bubbrubb in forum General Hardware Discussion
    Last Post: 04-20-2004, 02:19 AM
  3. Bristol, UK, council car towing story...
    By Scouse Monkey in forum Off Topic
    Last Post: 04-02-2004, 07:34 PM
  4. well, looks like my car pc just died
    By siueclipse in forum General Hardware Discussion
    Last Post: 02-04-2004, 11:46 PM
  5. god damn university car regulations
    By MikeHunt79 in forum Off Topic
    Last Post: 09-27-2001, 11:02 AM
