If you want to do it right, run it thru a relay and switch the relay with that switch. That switch might work for a while, but its not made to handle that much current for long periods of time, thats why they make relays.
ok, i wanted to wire a switch into the 8awg power wire that i've got running from my battery to my amp & inverter. So, I've got this switch from Radio Shack
http://www.radioshack.com/product.as...t%5Fid=275-712
It seems like that the easiest way to connect wires to this switch is with "quick disconnect" terminals, such as these
http://www.radioshack.com/product.as...t%5Fid=64-3131
however, the biggest that I can find that type of connector is for 12-10awg wire.
any suggestions on what to do, or what i need? much thanks.
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
12-10AWG connector will work. I know it because I am using it now. Buy the bare type connector and use with heatshink tub intead of insulated type connector.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
well that was why I got a switch that was rated for 30 amps. I assumed it would be able to handle it. I did this, because I wanted to keep things as simple as possible, since i'm a newbie when it comes to basic electrical/wiring stuff.Originally Posted by Pokey
So, to use a relay in conjunction with the switch (for the purpose of taking the heavy current away from the switch), i need to wire the switch to a separate lower-current circuit? Like I said, I'm no pro when it comes to this electrical stuff...
http://www.teamdelta.com/products/prod1.htm
Bigger switch
www.mechatroniks.com/wrx - Car PC Project/Dash Kits
