Results 1 to 10 of 13
Thread: Morex 3688 RAM
    Low Bitrate SonicCobra03's Avatar
    Sep 2003
    STL
    Morex 3688 RAM
    Will normal size RAM fit in the Morex 3688 case? I did a , but came up empty. The specs say that the RAM is restricted to 1.25". I've only heard of .8" RAM.
    Maximum Bitrate Rundell's Avatar
    I just put together a system in that same case. I'm using just regular DDR RAM... I'll open it up tonight and measure it for you when I get home just to make sure
    Constant Bitrate fondoo's Avatar
    Rochester, NY
    i purchased a 512MB stick from crucial.com and it fits fine.
    Sep 2003
    STL
    Did either of you guys fit a 90 watt opus in there too? I'm still waiting for the case to come in, but it looks like it will be close.
    No I did not put a 90W Opus. I'm using a PW120M.
    I did measure my Ram. It measures 1" 5/16 from top to bottom. There isn't any room to spare either. Just enough for a flat ribbon cable to run over top of it.
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    doesn't it have a dc-dc p/s? Don't you just need ITPS with it?
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
    Sep 2003
    STL
    Quote Originally Posted by vcbb5
    Yes it does have a DC-DC power supply that comes with it. Opus is just better.
    Feb 2001
    Somerville, MA
    Quote Originally Posted by SonicCobra03
    I put a 90W OPus in mine, but you have to drill some new holes. I ended up mounting it upside down under where the CDROM goes, attached to the CD/HD bracket. I am probably also going to cut a small hole in the side of the case for the 12V/GRD/ACC plug to attach.
    Twostep
    Aug 2002
    Kansas
    wouldn't ITPS + the current dc-dc p/w work? Just no crank-start, etc?
    My Mazda 3s
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Wait a while until MikeH of Carnetix has his power supply for sale. I'm beta testing it, and can't say too much detail due to the NDA, but i have to say it is awesome
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  1. Opus pw-70a fit Morex 3688??
    By fondoo in forum Power Supplies
    Last Post: 05-26-2004, 07:01 AM
  2. Got the Morex 3688 today!
    By milleda31 in forum General Hardware Discussion
    Last Post: 03-22-2004, 04:48 PM
  3. morex psu noise fix
    By starfox in forum Power Supplies
    Last Post: 03-15-2004, 07:19 PM
  4. FS: Morex PSU From Morex 3688
    By bklynkaos in forum Classified Archive
    Last Post: 02-09-2004, 12:04 AM
  5. upgrading ram on comp
    By cubanmoses in forum General Hardware Discussion
    Last Post: 07-28-2003, 02:53 AM
