Results 1 to 4 of 4
Thread: Anyone using ATI AIW video card?
    Newbie technopsych's Avatar
    Mar 2004
    Just wondering if anyone is using the ATI All-In-Wonder video card and what your experience is with this piece of hardware. I recently purchased the 9600XT and I have noticed two things;
    1) I hooked up the FM radio antenna and I got pretty poor reception. Anyone had any luck with this? (I sure hope so, I was counting on this feature).
    2) Interestingly, when I tried the card's TV function while hooked up to my Lilliput, the screen went totally black. So, on my system there is a conflict between TV and Lilli screen.
    On a final note, has anyone found a good FM antenna amplifier - I am looking. Thanks in advance.
    May 2004
    I have an ATI AIW 8500DV.
    1) Unfortunately, I don't have FM in this unit.
    2) Need more information on this. I have a Xenarc. Are you hooking up the composite-out of the AIW to the Lilliput or thru the VGA?
    As for FM antennas, best thing to do is if your car has an FM antenna, to hack it up and put it into the AIW.
    Oct 2003
    Toronto, Canada
    Quote Originally Posted by Kermee
    You should definately run it through VGA, composite will give you a very blurred image as compared to VGA. Just give it a shot on your TV and you will see what i mean. Besides, if you want to do it through composites, why not just get a cheap lcd that's widely available on ebay for a little over a $100, throw a touchkit on it and you're done. The whole point behind bying Xenarc's/Lilliput's is the VGA input.
    And yes, just tap into your car antenna.
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
    Nov 2003
    on all ATI AIW's the composite output is probably defaulted to be primary display and therefor only shows the video image (because overlay only works one screen) on the composite screen, download the latest drivers and make sure under the display tab in the display properties that the VGA is set as the primary display. and if it is.... are you sure you have all of the codecs you need installed?
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. Replies: 5
    Last Post: 04-21-2005, 02:17 PM
  3. AAAARGH!!! Datalux=death for my video card!
    By craashmann in forum LCD/Display
    Last Post: 05-21-2004, 02:58 AM
  4. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 04:14 PM
  5. Can I hook up a laptop LCD to the ATI Xpert LCD video card???
    By btomasie in forum General Hardware Discussion
    Last Post: 04-26-2000, 10:17 PM
