1.) why are you running power from the head unit and what are you trying to power.
you run a positive (+) (remember to put an inline fuse, or suffer the consequences) wire from the battery and run the negative (-) wire to the closest piece of bare metal near the device you are powering.
you should run the a/v wires on the --->Opposite<--- side of the car, if you run the power cable on the left then run the a/v on the right and vice versa
LinkBack URL
About LinkBacks
