Results 1 to 10 of 10
Thread: Pentium 4M or underclocking?
    May 2004
    Has anyone used a P4M in a mini-itx board that does not say it explicitly supports it? I know the Comells say they support it, but I would think other Intel chipsets should too.
    Or has anyone tried to underclock a desktop P4 to reduce heat and power consumption? My understanding is that the M chips are usually just the best silicon underclocked.
    I like the price/performance of the P4, but I want to use a smaller power supply (<= 100W) and reduce the heat. Any input is appreciated. Thanks.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    You won't get as low on heat/power as a pentium M for the same performance by underclocking, but if you have a P4 already it may be worth seeing how far you can underclock and lower the voltage. You should be able to reduce the heat/power useage. However the PM & P4M are designed to run at reduced voltages so their performance will be much better for the same power/heat output.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I noticed very little heat or power gains by underclocking my anthlon from 1.4 to 1.0 Ghz. I'm currently running the anthlon @ 1.4Ghz on an mAtx motherboard w/ integrated GeForce and 7200 rpm hard drive as well as a bunch of USB devices and draw about 7 amps at max power usage, which is under 100 watts. Heat was a bigger issue but adding a more powerful fan fixed that easily.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Did yopu reduce the voltage as well as underclock?
    Jan 2004
    Quote Originally Posted by pip
    Not all the clock / voltage settings allowed the computer to boot. I know I tried reducing the voltage, but I don't remember if it worked with the voltage reduced or not. I stopped trying different things after I put the bigger fan on and it stopped crashing cause of the heat.
    Nov 2003
    Seattle, WA, USA
    How about Athlon XP Mobile
    Around 40-45W for the XP2000-2400.
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    i just bought one from newegg, the 2400+ 45 watt for only $77. Should go nice with my shuttle sk41g.
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Quote Originally Posted by vcbb5
    I just got a 2600+ 45 watt for $99. I'm going with a standard ATX Asus m/b I already have and will custom mount it using a m/b tray/back panel to support the expansion cards. Just make sure you use a smaller heatsink to avoid damage to the m/b (more mass=more stress), I'm getting the following:
    Speeze low profile CPU cooler
    pip
    pip is offline
    Mar 2004
    Parker, CO
    I got the speeze low profile copper heatsink from Newegg. On the bench my Athlon-M 2600+ is running at 2ghz and 31C (at least according to the m/b).
    Seems to be cooling the CPU pretty effectively.
    http://www.newegg.com/app/ViewProduc...150-029&depa=0
    New York
    Nice and cool there. Was going to do that myself but put in a 2400+ Desktop Chip instead. Though just wanted to add a tidbit here for those running the Desktop Chips and even for you mobile users (maybe). My processor was running 65C Plus. Since then I installed CPUIdle (http://www.cpuidle.de/). Now on a much hotter day and full sun, i ran video's for 30 Minutes plus and CPU Temp maxed on me at 55C. Big difference if you ask me. Worth a usage. And no, the WinXP manager does a lame job at keep cpu temps kool.
    mark
  1. WTB Pentium I MB (or higher) with onboard sound
    By arcane004 in forum Classified Archive
    Last Post: 01-14-2004, 09:54 PM
  2. Pentium M Mini-ITX Available @ End of November
    By shadowlessman in forum General Hardware Discussion
    Last Post: 10-03-2003, 11:50 AM
  3. Pentium M Mini-ITX!!!
    By Defiler in forum General Hardware Discussion
    Last Post: 09-08-2003, 01:31 PM
  4. FS: Sharp 10.4" LCD and Pentium 3 Single Board Computer
    By Scrapez in forum Classified Archive
    Last Post: 02-05-2002, 08:10 PM
  5. pentium 83 fast enough?
    By justin146 in forum General Hardware Discussion
    Last Post: 02-20-2001, 09:19 AM
