anyone know ?
hi all
i need someone help me to hookup lcd that i bought from timeline.com. I follow the direction to setup and only the backlight is working which is obviously normal. none of the lcd working. I have 4x40 and 4x20. please help.
EDIT
ok
I get it work finally with -5v from motherboard. the only problem i have now is that not all the line is turn on
like
line1.......... turn on --------
line2 nothing
line3------------ turn on -------
line4 nothing
the 4x40 has 2 enable lines E1 and E2 but the 4x20 only have one E line. is this right
please help
[This message has been edited by noproblem (edited 07-07-2000).]
anyone know ?
not 100% sure that this is your problem but I have the same display (40x4) and i was using the plugin from inmotion for mine (i assume ure doing the same) and in the .ini file there is an option at the bottom that asks for the type of parallel port, make sure that it is an EPP (i believe). if that doesnt work, try the other options for that same setting. also check your bios and see what the parallel port is set at in their. make it an EPP and try it out. If anyone can give a definite it would help, but mines not actually even hooked up because of lack of case, but I know it does work. wish i could help more.
Grand Am-P3
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
