Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Question on Line Out of M10000 and Audigy NX
    Feb 2004
    I'm debating whether I should grab an external sound card from my m10000. My car audio system is high end and I plan on feeding the aux in of my deck with the line out of whichever option I choose. I'm wondering a couple of things:
    Is there any reason why the Line Out of the NX would be better than the onboard audio of the M10000.
    Is the line out on the audigy line level? Every spec sheet says line out/headphone(implies amplified). Is there a selectable switch to make it line level?
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    You can grab a external sound card for your M10000 to improve the sound quality.
    If you allready have a USB hub up front and you plan on hooking the soundcard up to your headunit, you won't need to run any audio cables from the back trunk or where ever your PC is. That's what is cool about using the USB soundcard.
    The Audigy 2 NX has a line level out for stereo setup's but is a 1/8th sized jack. You can convert it easily to RCA. Along with that output it also has a seperate mic and headphone jack.
    To get the best audio though from the Audigy 2 NX you should just bypass the headunit and go from the Audigy 2 NX into amps like I did. I have two amps in my trunk and Dolby Digital 4.1 Sound.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    Mar 2004
    Quote Originally Posted by Mears
    This is where you are confused, line level outputs and headphone outputs are basically the same thing. Go hook your mp3 player up to your headunit, it will work just fine. The headphone jack and the line out jack on the audiy 2 NX are the same thing, they just put one of the front and one of the back (or something along those lines, use the Audigy 2 Platnium myself).
    I have not heard what the integrated audio sounds like on a M1000, but I bet it will be disapointing. If you have a good stereo system, you better go buy a different sound card, because its going to sound like **** otherwise. The line outs/headphone outs on either cards will be the same signal, but one is going to sound a hell of a lot better than the other (much less noise and interference, less distortion).
    Jan 2002
    Long Island, NY
    The Audigy 2 NX does not share the headphone and the line out jack.
    It does share the line in and mic in jack though.
    It has 7.1 and can utilize all the outputs and uses them seperatly to output discrete channels.
    Here are some pics I grabed from New Egg:
    The 1/8th to the right is the front left and right channels.
    Jan 2002
    Long Island, NY
    And here is the side:
    The 1/8th to the left is the headphone output, or in 7.1 mode the side left and side right channels.
    Those are the speakers to your right and left inbetween your front speakers and rear surrounds.
    I am thinking about going with 6.1 in my car. ( Disabled the center channel)
    Feb 2004
    Ummm...I could be mistaken, but a traditional headphone jack isn't line level. I believe minor amplification is done.
    I'm not sure why using feeding an amp directly from a mid-range sound card would be better than feeding it from 4-6V Pre-outs on a deck with a decent DAC. Not to mention many individuals use multiple amps and can benefit from mutliple pre-outs on aftermarket decks.
    Leslie: That 1st picture is showing the digital outputs on the soundcard. You wouldn't be able to send those to the aux-in of a head unit.
    Man
    Man is offline
    Low Bitrate Man's Avatar
    Nov 2003
    You would be correct, except the Audigy has seperate headphone/line-out. Headphone on the side and line-out on the back. Now I could be wrong, however I don't believe it is true Line-out (Line level does have amplification, however it is fixed as a raw analog signal can vary from device). If you can adjust the volume either on the actual unit or on the PC's volume control it is not true Line-level out. The ONLY sound card I have that had a proper line-out is an old Sound Blaster 16 ISA, great card and was great for un amplified speakers as it had a great amplifier on it that most cards (and defently not onboard) do not have.
    Geeze Im going off topic, yes the first picture has digital outputs on the left, the analog ones are on the right which are gold looking. And if you have a USB cable running to your amp you are not going to get as much ditortion as with running RCA cables, however if you take care and have a good head unit you will be better going that way.
    Jan 2002
    Long Island, NY
    The 1/8th are not digital out.
    I have used a headunit before and now I have no headunit.
    My CarPC uses the Audigy 2 NX and I have tested it.
    Which headunit can do 7.1 sound like the Audigy for 100 buks not to mention?
    The Audigy changes the amplicfied headphone out to line level once you change the speaker settings in the creative control panel.
    Jan 2002
    Long Island, NY
    Have you ever heard my system Man?
    I have no headunit and my friends with headunits drop there Jaws.
    Variable Bitrate stimps's Avatar
    Nov 2001
    brisbane
    can anyone tell me what is the limit that you can flog your USB system? at the moment I have a mouse and keyboard running off USB, and I am considering a USB wireless network dongle to connect to the house network (and the net) and also, a USB sound card to get the music clearer and up the front (no audio cables) to the amp!
    And later, Id like to connect a USB camera looking out the back! (phear!)
    Is my system USB gonna crash?
