travla C134 and the Opus 150w PCB supply.
Anyone know for definate if an Opus 150Watt PCD only PSU can be fitted into a Travla C134 case?
I'm planning on revamping a little when I change my car, getting hold of an 8" Lilli, and mounting a C134 in the dash if I can.
Otherwise it is a Cubid2699R in the shelf above the glove box (still hidden below the dash).
Hoping to sort out an Alfa Romeo 75, and mount the Lilli infront of the Alfa ARC display, when I'm in the car.
Raw Wave
Originally Posted by
rando
It won't fit.
bugger, that has sorted that out then. looks like a 2699R it will be then.
BTW, I was talking about the bare OPUS PCB version, not the ful cased or U bracket version.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
