Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 61
Thread: ColdHeat Soldering Tool!
  1. #11
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by gambit32
    A buddy of mine at work and I saw this in the paper a while ago. So he bought one. He says it's not that great. He got his off of ebay. He said the tips on it were very fragile.
    yeah, i would assume the tips are not very dense, which is why they can heat so quickly.
  2. #12
    Variable Bitrate wkolodny's Avatar
    DC
    Now you tell me.
    Don't Fear The Gurkey
    Click here to check out My Setup
  3. #13
    Nov 2003
    If he found that the tips were fragile then he used them to solder. If he did that then he was using it wrong.
  4. #14
    Oct 2003
    Toronto, Canada
    Well friend of my friends cousins friend... Nah really.. As binary said, it probably is more brittle than your conventional tip, but personally i dont see what exactly do you have to do to break a tip We'll wait and see Should arrive next week!
    VIA Epia II
    256MB 266DDR Ram
    90GB Wester Digital
    Bluetooth/Deluo GPS
    Lilliput 7" Touchscreen
    Mazda 6 Carputter > Click Me!
  5. #15
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Oh wow, perfect for those of use who don't have a workshop/garage and have to work in the yard/street. No need to trail wires, and extensions.
    Hmm, do think geek ship overseas? Lets have a look shall we.
    4x4 in a turbo stylee.
  6. #16
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    why not get a 12v soldering iron ? I have one with spring clips to the battery in the car, and i extended those leads, now I can solder all over the place in the car with no AC electrical leads
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
  7. #17
    May 2002
    Warrington UK
    Doh, that would be the easy option. But I've just "ThoughtGeek" and ordered one. Got to have some cool tools in the tool box you know, dremel gets lonely when faced with just screwdrivers and the "Big Hammer". This can keep it company.
  8. #18
    Dec 2003
    Michigan
    I have one of theese. It's ok, not great. The way it works is that the tip is two conducing materials seperated by a small gap. You place the item you wish to solder across the gap wich causes conduction thus heating the metal and allowing you to melt solder.
    It doesn't work well for anything not solidly mounted, i.e. tinning wires and such. Also, the standard tip is a little to large for any detailed work.
    I first saw this on thinkgeek, and did a search, purchased it from QVC.com (they were chapest at the time). Thinkgeek does have other tips available, I think I'm gonna try some of them before I give up all hope.
    Again, works fine for soldering stanard/large items. I've used to to connect PL-259's to coax without problem, but have had problems tinning wires, and soldering circuit boards.
  9. #19
    May 2002
    Warrington UK
    I ordered the smaller connical tip while I was at it, so I can see if it works OK.
  10. #20
    DC
    Got mine today. Its is Okay. Not great. Good for soldering wires together. Crappy for doing any detailed PCB work. I didnt get the small tip. That may have helped but it will come in handy for wiring in my car.
  1. attn: trustworthy soldering pros
    By aoLhaTer in forum LCD/Display
    Last Post: 03-08-2004, 11:52 PM
  2. soldering iron
    By Cordell in forum General Hardware Discussion
    Last Post: 03-14-2003, 02:52 AM
  3. tool to make pics of equal size .....
    By felix99 in forum Off Topic
    Last Post: 09-15-2002, 09:56 PM
  4. Can a soldering iron "burn down"
    By izaram in forum Off Topic
    Last Post: 05-13-2002, 06:17 PM
  5. Trouble soldering
    By Chris Snyder in forum General Hardware Discussion
    Last Post: 08-28-2000, 01:37 AM
