Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: ColdHeat Soldering Tool!
  1. #41
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    this thing is just a pos. first off the whole "cold" aspect of it is bull****. in the commercial the guy touchest it two seconds after he solders two wires together. I attempted this and burnt the **** out of my self. Metal does not cool down that fast. Secondly, I agree with everyone else who said its to frustrating to use. Its too difficult to use the head that its supplied with, and it has already proved to be so worthless to me that I do not intend on wasting any more money trying to make thos thing work.
    I went to radio shack and purchased a regular soldering iron.
    PC Components:
    My work log
  2. #42
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Quote Originally Posted by odleon
    our butane pencil iron is waaayy better and just as portable.
    Amen to that. I took my "revolutionary" iron back after one full day. It sucked. It was very difficult to control the flow of solder and very fragile....and I was being careful. I have 15+ years of soldering experience, and I agree, once you try a butane iron you wont go back (unless you bought a cheap one!)
    2005 Ford Focus ST
  3. #43
    Nov 2004
    Angry
    Yup this thing freakin sucks... I ordered mine off TV about 2 months ago and finally got it just hte other day :-( Anyways, I was excited but that was short lived when I saw the tip was partially broke... that's when a little note fell out of the shody case saying "Be careful with the tip because it is very delicate"... thanks a freakin' lot!
    Anyways, I thought all is not lost I got a pair of free wire strippers. Well damn, those things suck worse than the soldering tool. They are the cheapest piece of crap ever!
    Worst $30 I ever spent... returning NOW!
    My review recap: If you want a piece of ****... order this ASAP. Or you can just down some chinese food and wait 30 minutes or so, same ****.
  4. #44
    Feb 2004
    The Cold Heat soldering tool is what's called a resistance soldering tool, because it uses electrical current flowing across the part to generate heat, based on the part's natural resistance.
    Here's some examples of some suitable resistance soldering tools for hobby use:
    http://www.ares-server.com/Ares/Ares...partment&ID=81
    Notice the prices - $350-400 each.
    I have one of the Cold Heat tools, and it CAN be a useful tool, but I wouldn't use it on anything electronic in nature because what you're applying to the joint is not heat, but electricity.
    Add to the fact that it's not temperature controlled (something like 800 degrees?), and you can easily damage anything electronic with too much generated heat.
    At least with a 35 watt pencil iron, you know it's rated for 35 watts, and that's all it will do.
    I would certainly use it for soldering large connectors to wires, such as for 12v power or grounding, but I would definitely NOT use it for anything small and electronic in nature.
    Edit:
    If you wanted a GOOD soldering tool, and you were willing to invest $70 in one, this is a good candidate:
    http://www.ares-server.com/Ares/Ares...oduct&ID=81014
  5. #45
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Quote Originally Posted by Peoples
    You must have got that one that doesnt work because my heatcold. the tip cools in less then 3secs.
  6. #46
    Dec 2003
    Portland, OR
    Quote Originally Posted by Giuliano
    Edit:
    thats the same iron I use with my delicate electronics...had it for 4 years and only replaced the tip. I Use an Isotip Butane for portable work though.
    2005 Ford Focus ST
  7. #47
    Maximum Bitrate MoFo's Avatar
    May 2004
    TX
    Mine cools down in no time. Perhaps your tip had some hot solder on in when you touched it. You shouldnt touch hot solder..its hot
  8. #48
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    I like the tool...but I LOVE THE WIRE STRIPPER the comes "free"
    just love it
    yep, i do
    DICE Los Angeles
  9. #49
    Jan 2003
    Ruston, LA
    Quote Originally Posted by yunusyu
    just love it
    yep, i do
    It ****es me off that they act like the wire stripper is a "new" thing
    in the commercials though. I have had one like that for at least 10
    years, and I don't imagine it was "new" then.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #50
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by frodobaggins
    They'll always be 'new' to someone.
  1. attn: trustworthy soldering pros
    By aoLhaTer in forum LCD/Display
    Last Post: 03-08-2004, 11:52 PM
  2. soldering iron
    By Cordell in forum General Hardware Discussion
    Last Post: 03-14-2003, 02:52 AM
  3. tool to make pics of equal size .....
    By felix99 in forum Off Topic
    Last Post: 09-15-2002, 09:56 PM
  4. Can a soldering iron "burn down"
    By izaram in forum Off Topic
    Last Post: 05-13-2002, 06:17 PM
  5. Trouble soldering
    By Chris Snyder in forum General Hardware Discussion
    Last Post: 08-28-2000, 01:37 AM
