doesnt your computer have an AUX in? or mic? use the comp then the comp to the pionner or buy and audio/video switch
sorry if this is a dumb question but how would I wire in sound from my carputer through my headunit if I already have XM radio installed in my auxilary input? I have the XM receiver wired into my head unit via the ip bus. Thanks!
btw, this is a pic of my setup so far: 1997 Audi A4
I'm going to be installing the mobo/hd/slim dvd in the rear armrest. I'm planning on molding a custom armrest top to house the dvd player, led fan, usb ports, and some cooling vents. I just have to figure out the sound thing first :-/
You might be able to re-wire the IPBus cable so you can just mix the aux signal with the XM radio. But i dont know if the reciever will allow the aux to be enabled as the same time as XM.
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
You need something like the CD-RB20 adapter. It allows an IPBus device to be plugged in along with a set of RCA inputs.
