Results 1 to 9 of 9
Thread: BEST WAY to mount CARPUTER?????
    Aug 2003
    Exclamation BEST WAY to mount CARPUTER?????
    What is the best way to mount the carputer?
    I'm currently using a wooden board which I bolted down to the trunk floor. I want to screw my carputer to the board, but I'm worried about "the shock factor". I'm not so worried about my car amps, because I think they were built to take it, but my computer I am worried about, esp. because of the HDD.
    I tried using some grommets and bolting it down, but it wasn't tight enough and kept getting loose..
    Should I just screw it down and hope for the best?
    Should I raise up the wooden floor on the sides and screw the carputer to the middle, so like a suspension bridge, it will take the bumps more smoothly?
    HELP!!
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    no don't do a suspension, just simply bolt/screw everything down to your board and make sure that board is "bolted" down securely. Also keep it away from the subs.
    Mine needs to be updated.
    Aug 2003
    But won't that cause too many vibrations? I don't want to have to buy a new HDD every couple of months..
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Quote Originally Posted by sq_geek
    Mount your hdd vertically, so that the heads won't crash against the platters, and you should be fine.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    do you drive off road alot or on paved roads? Your suspension on your car should handle everything.
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    Quote Originally Posted by Pepe
    but the heads will fail that much faster... Never had a head crash agains the platter, while i have had head motors fail. Vibration is bad for any setup with moving parts...
    car computer rev 5: 8" lilliput and usual suspects
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The PC DVD player in my Supra doesn't even skip when play DVD or CD. The HD will take much more shock than you think. Mount it vertically and on the side (left/right) will help a little.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Aug 2003
    anyone know how to vertically mount it in a cubid 2699R case (small black case) with the PCI slot in use? :\
    I don't think I can...
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Turn the case on its side
  1. can i mount my carputer sideways/perpindicular?
    By delussional77 in forum General MP3Car Discussion
    Last Post: 05-25-2004, 09:31 PM
  2. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 01:59 PM
  3. Replies: 1
    Last Post: 02-03-2004, 01:02 AM
  4. Replies: 0
    Last Post: 07-14-2003, 03:12 PM
  5. Where to mount my new carputer?
    By mtmsol in forum General Hardware Discussion
    Last Post: 09-04-2001, 04:30 PM
