Results 1 to 6 of 6
Thread: wire gauge question
    Constant Bitrate skeurton's Avatar
    Mar 2004
    newport news, va
    wire gauge question
    i'm trying to solder wires to the board of my laptop docking station so that i can extend the power button. i figured out which points to short and everything. i tried this once already and used 18AWG hookup wire. it worked, but i think the wire may have been too thick and stiff. when i put it back together, the solder cracked and broke the entire switch off the board. that was pretty much the end of that.
    so i got another docking station and my question is what type of wire should i use? is 22AWG wire thin and flexible enough?
    Mazda 6 Carputer
    elocine.net {NEW ALBUM AVAILABLE FOR FREE!!!}
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    are you using solid or stranded?
    rebuilding carpc... kinda..
    Mar 2004
    newport news, va
    it was solid. i suppose stranded would work much better?
    Mazda 6 Carputer
    Nov 2003
    CT
    stranded will be much more flexible
    Mar 2004
    newport news, va
    cool, thanks. and i should be able to find this at radioshack or some electronics store?
    Mazda 6 Carputer
    Nov 2003
    CT
    should be able to. we sold stranded 18ga wire at a hardwore store i worked at. or any car audio store should have it too. i'm not sure about the size you need.it depends how many amps are going through the wire. if its just a pulse like for a computer psu 22ga should be ok. otherwise you should check it out.
  1. Is 8 gauge wire heavy enough? Amp + PS
    By mhorton in forum Power Supplies
    Last Post: 05-23-2004, 11:47 AM
  2. Replies: 37
    Last Post: 05-17-2004, 07:01 PM
  3. What gauge wire to use?
    By owenjh in forum Power Supplies
    Last Post: 05-09-2004, 10:52 AM
  4. What Gauge Wire To Use
    Last Post: 02-14-2004, 04:16 PM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 11:13 AM
