There are lots of VGA to TV converters (comp & s-video) which have VGA pass through so you can display on both.
I think the only probs you will have is getting the resolution correct for both.
Craig
ok so what im looking for is a card that will either:
a. output a TV signal via Svideo or composite at the SAME TIME as my onboard mobo VGA outputs the same signal.
or
b. a vid card that has both VGA and Svideo that can do that same as above.
i had a geforce 3 Ti500 but it would only output to either svideo or VGA not at the same time.
what im looking to do is
have the VGA go to my lilliput screen in my dash and have the svideo signal go to a flip down monitor in the back so they display the same thing.
thanks!
Craig
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
Are you sure about your Ti? Every GeForce I've had w/ TV out supported mirror, and extended desktop.Originally Posted by dannn
If nothing else, if you're using Windows, you can probably clone the monitors by using a dual-card dual-head setup. Of course the TV out card would have to be PCI so it didn't override the onboard AGP, because as soon as you stick an AGP card in the slot, the onboard video is turned off (on most boards, at least..).
Other than that, yeah the passthrough VGA->TV converters aren't too bad.
89 Celica, CarPC installed, 1st bday :)
http://www.fishy.net.nz/carpc/
- MediaEngine
- Epia V8000
- 80GB WD 7200RPM HD
- Xenarc 700TS
- SB Live
- Opus 90W
- CIMR100 remote
- Deluo serial GPS
- D-Link USB radio wired to power antenna
