Results 1 to 10 of 14
Thread: dvd spec
    Nov 2000
    Cornwall, England
    Post dvd spec
    i been looking through the archives with referance to the lowest spec pc that will play software dvd without any problems but there does not seem to be a real solid answer.
    What is the lowest spec you are running
    Edie209
    Edie209
    http://www.ridgeway.plymouth.sch.uk/majikfish/majikfish.htm
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    Post
    The reason that you cant find a solid spec on software DVD is that there is no solid minimum system requirements for it. Every part of the system effects performance: CPU RAM, grfx card, etc. Then again, if you are really worried, you can pick up a decoder card for ~$30....
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    You'd be safe with a 400-500 Mhz.
    My amd k6-2 350 ran dvds at about 20 fps.
    May 2000
    Guadalajara, Jalisco, Mexico
    Post
    How you measure the FPS you are getting?
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    Post
    I had a PII-350 that ran them flawlessly with just software decoding. It couldn't do anything else at the same time, so you may want to go a little faster. Also make sure you have DMA enabled to your DVD drive.
    Bj
    Bj is offline
    Aug 2000
    Perth W.A Australia
    Post
    I'm running a Celeron 600 II with 64MB ram, 16X slot loading drive, and a 16MB video card. It is quite crap on sodtware DVD playback, freezes, misses frames, sound drop out etc. Then I enabled the DMA on the drive, and it is a lot better, (well it's actually bloody nice) but it still stops every 5 mins or so, and the DVD spins up faster, and then it carries on. I can't seem to stop it doing this? But it just goes to show even a resonably fast machine is poor.
    Meatballman, how on earth did you get it to work on a PII350? was it smooth?
    BjBlaster! Car MP3 & Carputer!
    http://bjblaster.mp3car.com
    "The solution to one problem is only the begining of another"
    bjblaster.com
    "The solution to one problem is only the beginning of another"
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Celery chips suck at multimedia stuff. I can see a pII running it right at 350 but not a celery at 600.
    That 20 fps measurement was just kinda guess work. It wasn't super smooth, but it wasn't really choppy either.
    Mar 2000
    Washington DC
    Post
    I have a 233mmx w/ 64megs that runs powerdvd smoothly. I dont have any choppy video. If you tweak your system and keep the system resources to a minimum..it should work fine.
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Toxic - What vid card you running?
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Jul 1999
    Hartsville, SC
    Post
    <font face="Verdana, Arial" size="2">Meatballman, how on earth did you get it to work on a PII350? was it smooth? </font>
    It was very smooth. If some program in the background kicked in, I'd get a frame glitch or two. I think older Celerons only have 64K (or 128?) L2 cache, whereas PII's have 512K. That makes a significant difference in multimedia apps. In case it matters, the vid card was a Creative 3DBlaster Banshee PCI, which is known for using very little processor power and the DVD was a Pioneer DVD-104S slot load. I successfully watched movies smoothly in both PowerDVD and XingDVD.
