The hotter the CPU the more likely it is of shutting down. If you were running it reliably at a higher temperature then it is probably another component causing the problems such as the motherboard controller processor, ram, VGA card e.t.c. This would be more likely as the temp in yr case would be reduced with the new fans, but with the old setup it was hotter.
Sounds quite strange tho, 85C is pretty dam hot, i wouldnt recomend running it at that temperature, you may get away with it but it'll definitely reduce the life of your components.
LinkBack URL
About LinkBacks
