Results 1 to 10 of 18
Thread: Griffin PowerMate? Can't get it to work... help please!
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    I purchased the Griffin Technology PowerMate on eBay and received it today. It didn't come with the installation disk but I quickly found software on the Griffin Tech site... DL'ed it and installed it... I have been jacking around with the thing for quite awhile today and have had NO luck. When I first plugged it in, the light was pulsing slowly... now the light is on solid... I have tried plugging and unplugging it several times, uninstalled and reinstalled the software a couple times and messed with all of the settings. STILL no luck! I am wondering if the software I DL'ed from Griffin (1.5.2) might be some kind of patch or something that needs to be installed over the OEM install from disk (if that makes any sense)... Any suggestions? I plan to continue messing with this thing ALL night until I get SOMETHING out of it... I assume that since the computer recognizes me plugging it in and unplugging it, and the fact that it lights up, that it ISN'T a bad PowerMate... I wanna figure it out ASAP so I can rest assured that I didn't get taken. Thanks in advance. TTYL!
    Coach... aka Randy!
    May 2004
    If anyone here has the PowerMate and the original installation CD, is it possible to copy the "PowrMate.inf" file in the drivers folder and possibly send it via email? That is the ONLY thing so far that I have found that I could do because I don't have the original CD. If anyone can help a brotha out... please, PLEASE email it to me... rreed17@kc.rr.com
    TTYL!
    Coach!
    Variable Bitrate wkolodny's Avatar
    DC
    Don't Fear The Gurkey
    Click here to check out My Setup
    May 2004
    Thanks for the reply... but... I had already read that page... I have searched my computer and figured if it was installed correctly, I should be able to find the PowrMate.inf file, correct? Well... not anywhere on my puter. Anyone here have the PowerMate? If so, and IF you have your installation CD available... I'd REALLY appreciate it if you could afford a copy of the PowrMate.inf file. Or, I would like OTHER suggestions.
    TTYL!
    Randy
    DC
    Quote Originally Posted by coachreed
    TTYL!
    Randy
    I downloaded the drivers from griffin and installed them and they came with the PowrMate.inf file. I can send it to you but there must be something you are doiing wrong if you installed it and cant find the file. Running XP?
    Mar 2004
    Germany
    Hi coachreed,
    I had the same problem at the beginning. My Problems (think so) caused because i have a USB keyboard and Mouse. I think the Powermate driver has Problems when there are more HID-Interfaces than his owne. I unplugged any HID-Interfaces and then only plugged in the Powermate. And than it worked. After this you can pluggin the Keyboard and Mouse. It should be working. I have the same Driver (1.5.2) from the Website. Sometimes the Powermate don't worke again and I must restart the procedure with unplugging and then plugin the Powermate...
    P.S: Sorry for my english
    May 2004
    Quote Originally Posted by wkolodny
    I DLed the software from the Griffin site and ran it. It automatically checked for updated software and then installed. I let it install in the default location and when it was done, it confirmed that it installed successfully. The problem with looking for the .inf files is that there is only the one programe DLed... the .exe file. If you have a separate .inf file DLed, I'd like to try that if you don't mind sending it my way... please? rreed17@kc.rr.com
    Quote Originally Posted by luebke01
    Hi coachreed,
    I appreciate your info... I'll try that out. Right now, I am setting it up on my home PC just for the sake of testing it... I have a couple other USB HID devices plugged into it. I'll try your suggestions. If this takes care of it, I hope I can overcome this with the carputer since my install will be completely in the dash... don't know how I'm gonna go about unplugging and plugging once its all said and done. The only thing so far on my carputer setup that might be USB HID is one of my touchscreens... but we shall see. Thanks a bunch... and btw... your english is just fine...
    Coach
    DC
    Coach
    When you run the exe it creates those other folders. Browse your hard drive after running it and you will find the file. I had the same issue with multiple HID devices. Same fix worked for me.
    May 2004
    OK, I unplugged ALL of my USB HID's... rebooted... plugged my PowerMate in... and guess what... it installed and initialized just fine... the problem is that when I plugged my USB Optical mouse, it caused some problems... I unplugged the mouse... no good... unplugged the PowerMate... plugged PowerMate back in... no good... unplugged powermate... rebooted... plugged PowerMate in... works great... but if I reinstall my mouse... the Powermate works fine UNTIL I reboot... UGH!
    Now, with my carputer, the only other USB HID at this point will be my secondary touchscreen monitor (assuming I get it to work correctly)... but if they won't play well together... this isn't gonna be very convenient. Is there any way to force USB devices to initialize in a certain order? I guess this is a price to pay for a device that was originally meant for Mac...
    Anyone out there have multiple USB HID's without ANY problems? If so, what devices do you have attached? Thanks in advance.
    Randy
    Constant Bitrate TaylorMade's Avatar
    Nov 2003
    Tampa, FL
    I have the powermate and the touchscreen running with no problems at all. In fact I have 7 other USB devices running with the powermate fine. I have a lilliput, an Earthmate GPS, a keyboard, a sound card, wifi card, a usb hub, and one last thing that escapes me.
    2008 Ford Expedition EL Ltd
    Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
  1. My 2001 Sport Trac Install
    By wkolodny in forum Show off your project
    Last Post: 01-30-2008, 11:18 AM
  2. Suggestions / Requests
    By LESLIEx317537 in forum FrodoPlayer
    Last Post: 07-29-2004, 01:23 AM
  3. Has anyone gotten a sproggy to work with EPIA boards?
    By rbarr110 in forum Power Supplies
    Last Post: 05-10-2004, 07:33 PM
  4. Griffin Powermate volume control help
    By bklynkaos in forum Input Devices
    Last Post: 02-08-2004, 10:48 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
