Results 1 to 6 of 6
Thread: Brainstorming glove box PC
    Jun 2004
    NY
    Ok, so I sat around on my *** all day and looked up specifications and stuff for the car PC and I decided that I can get away with turning my glove box into a computer case. I'll get the Epia MII 10000 board, the 150W opus, a dvd player (slim?), and a 3.5 HD. This way it will be easy to wire to my LCD screen and such. As for cooling in the glove box since it wont have much ventilation, I was thinking about making ventilation slats in the back of the glove box. Also, I was thinking about taking the A/C line from the feet-setting, and running a hose into the glove box (it will be unseen of course).
    Anyone ever tried this? See any problems?
    I have a long way until I'm ready to do my purchasing and work on the carputer... I need one small thing, $$$
    Never put off until tomorrow what you can do the day after tomorrow. ~Mark Twain
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by KingRudy
    I had mine in my glovebox with a vent fan out the back of it leading to some ductwork but still had heat issues. It got up to 155 degrees in my pc. Moved it under the back seat.
    Don't Fear The Gurkey
    Click here to check out My Setup
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    I'm going to do the same exact thing. waiting for my lcd though. I have taken out the black padding of the glove box to fit my micor-atx mobo. As far as the a/c is concerned, I don't think there'll be any problems. In the winter you can always detach the hose. I'll let you know, when I'm done.
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    Jun 2004
    NY
    awesome, lemme know how it goes because I still have a bit of time before I can put my plan into action
    Jun 2003
    Memphis - TN
    Anyone ever thought of putting fans to blow THROUGH the case (one or two to intake air, and one or two to exhaust the heat on separate sides of the glove box?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    where to intake, and where to exhaust...
    I am about to analyse how I will perform mine. Its a kiosk PC and I require to have the PC close to the screen, so the glovebox is kind of a must, unless I want to go a very different way then what I had in mind.
    anyone had heat analysys for summer weather inside a car without air conditionner?
    -Mars
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Glove box mounted laptop DVD-ROM using 15 foot IDE cable pics.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 01-08-2004, 02:03 PM
  3. 2000 Chevy Tracker Glove Box PC
    By nijel in forum Show off your project
    Last Post: 11-16-2003, 09:04 PM
  4. Glove Box Case
    By bjm2020 in forum General Hardware Discussion
    Last Post: 06-05-2003, 03:09 PM
  5. Motorizing my glove box...how?
    By SuperMatty in forum Classified Archive
    Last Post: 08-14-2002, 10:53 PM
