Bump, cause I want to know too... I have a Xenarc 700 TSV, need to know barrel plug size!
I just went to Radioshack with my Xenarc and Audigy and nobody there could help me with finding a barrel plug. However, by the ac-dc adaptors they had a bunch of them on a chain that you could test with and it appeared that the Audigy was a size "B". Someone please confirm this.
However, there were 3 different plugs that fit the Xenarc - K, L, & M. The K plug was the tigthest fit, but had the smallest diameter. I ended up picking up that one and didn't get anything for the audigy. However, now after coming home and comparing the size K plug to the plug on the ac-dc adaptor that came with the Xenarc, the stock plug is wider. I'm assuming it is either L or M, but I'm not real sure.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Thanks thanatos. I will buy this and try it out. Do you happen to know the size desginator for this? (K, L, M?)
2002 Honda CR-V
Bought it today. It is a size M, according to the package. It appears to be the right barrel diameter etc., but it is also definitely longer than the original one, so about 1/8" sticks out. Not usre if this could be a problem... possible shorting?
2002 Honda CR-V
I don't think is going to be a problem, did you try it already?? (when you move the cable it comes out??
