Results 1 to 6 of 6
Thread: Cadet FM tuner Card
    Jun 2000
    Massapequa, New York, USA
    Post Cadet FM tuner Card
    Does any one have a Cadet FM tuner card ? If so what antenna do you use to get reception. I am using on from radio shack but I want a clearer signal. It has to be an antenna that hooks into a coaxal connection.
    Jun 2000
    Canada
    Post
    You can use any fm cable, all you do is get a coaxial adapter (thats what the card orignally comes with). I dont really knoe how to describe it but they used to used on TV sets to get over-the-air "cable"
    May 2000
    Post
    I have a ADS Tech Cadet radio card. I just use an old tv antenna ("rabbit ears") and don't have any reception problems. I the card at home so i'm not too sure about any kind of reception problems in the car.
    aka_Lint
    Jun 2000
    Post
    thanks I'll try it out
    Jun 2000
    Post
    Quick question to anyone. Is there any way to plug the cadet card into the antenna in your car. I was trying to find an adapter to hook right into it for a cleaner install. Thanks.
    May 2000
    Ft Gordon, GA
    Post
    if the card has coax hookup all you do is buy an extension cable for you car radio antenna ($5.00 @ radio shack) cut off the male end an put a crimp coax female end on (you can also buy this @radio shack cheap!) i havent finished building my setup yet but this worked awsomly for a friend o mine.
    "if everything is under control, you're not going fast enough!"
