Results 1 to 3 of 3
Thread: itps and radio harness?
    Mar 2004
    Maryland/NOVA
    can i just tap into my headunit's harness for the switched and un-switched power?
    and if i connect directly to the battery does that mean connect a small wire to the battery itself?
    if i connect to the battery do i need a fuse in-between?
    thanks.
    2001 Acura CL traded for a 2006 Subaru Legacy GT
    7" Lilliput Touchscreen
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
    relocated HU faceplate
    Low Bitrate Hacksaw's Avatar
    Nov 2003
    Southwest UK
    I tapped into the radio harness on my install and it worked fine. If you were to connect direct then a fuse is a must to protect your equipemnt / car.
    2000 Vauxhall Vectra SXi
    EPIA M12000 / 256MB RAM
    PW-120 + ITPS
    Slot Loading CDRW/DVD
    30GB 2.5in HD
    Lilliput 7" VGA + Touchscreen
    GPS Nav
    Installation progress {+++++++} (Installed! :) )
    Mar 2004
    Maryland/NOVA
    thanks...
    NANO-ITX+m1-atx
    512 DDRsodimm
    60g SATA Laptop HD
    4x Apple DVDslot
    digimoto OBDii
    mS GPS
    mini BT keyboard
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Itps
    By storm in forum Power Supplies
    Last Post: 03-12-2004, 04:37 AM
