Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 85
Thread: Simply serial input circuit
  1. #11
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    The software above will work but the radio button display will be wrong if you try to use two inputs at the same time. Sorry I just threw this together real quick to show how the circuit works.
  2. #12
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    I have written a shutdown controller based on shorting pin 4 with 8 on the serial port, have a look here:
    New shutdown controller - software
  3. #13
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    FetLyd, were you thinking more of something that will display the reverse camera without going thru the computer? If so there is a way shown in the following thread, however it requires the purchase of another $70+ gadget to get it working. I am hoping somebody will find a way to switch the Lilliput from VGA to Video1 and back using a relay, so I could just have the backup cam come on whenever I am backing up - even with the computer off.
    Displaying reverse camera on a carputer?
  4. #14
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by weekendowel
    OK, I wasn't thinking of a shutdown controller when I posted this but none-the-less the two solutions are pretty much the same.
    The only difference is that your circuit floats the input pin (CTS pin 8) when the relay is open. I mentioned that such an approach is possible above. Still, I think the input values are undefined when the input voltage is between -3V and +3V. I guess it's possible the inputs have pull-up or pull-down resistors installed to force them to a valid value when floating. If not, then it's possible that CTS could read either high or low while floating. Obviously a resistor could be installed to force the pull-up/down if needed.
    The circuit here uses a DT relay so that the input line always gets a valid value.
    In any case, the software above should work with either circuit. Hopefully a future version of FP will support this mechanism to allow enable/disable of video playback and applications while the car is in motion (required in CA).
  5. #15
    Jan 2003
    Ruston, LA
    Quote Originally Posted by rando
    I've been hoping to get a feature added to Frodo to allow it to be used legally in California. Basically I need to implement an automatic mechanism to disable certain features (video playback, applications, etc) when the vehicle is being driven.
    Here is a simple serial port based circuit that will allow you to interface with your brake lights, ebrake switch, gear position switch or whatever you want. It only uses a single SPDT relay. Software must initialize the circuit by setting DTR high and RTS low (unless you want to use the +/-12v or +/-5v rails from your PSU). It can then read the on/off status of the relay over the DSR line. If you want the logic to work in the opposite direction, you can simply set DTR low and RTS high.
    DTR---SWNO
    RTS---SWNC
    DSR---SWPole
    Input --- Coil ---- GND or Input --- Coil --- +V depending on what you're interfacing with.
    I've tested this with a simple vb.net program and it works great. Hopefully one of the major front ends will adopt support for it (or something similar) in a future release.
    BTW, if you need more inputs (upto 4), you can add more relays. The SWPole lines can be hooked up to CD,CTS, and RI also.
    So, for testing purposes, say I get a SPDT switch.
    I hook it up like the diagram below.
    I set DTR Low
    I set RTS High
    Then I can read the status of the switch by checking the state of the pole line ? Right ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  6. #16
    Mar 2004
    Redondo Beach, CA
    @Frodo: Yes, assuming you hook the pole up to one of your serial input lines.
  7. #17
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Rando, I don't have VB.NET so I can't see what the code is. However I wrote a test one on VB6 to see how it work compare to your exe one. Now I need a serial cable so that I can use the "paper clip" switch to check the port. Maybe base on this I can code some thing like software shutdown controller as well. Now I don't really feel comfortable driving with the screen on and the cops is on the next lane.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #18
    Jun 2004
    Quote Originally Posted by Supermike
    No, just a simple usb webcam.. But however, i just cannot figure how to wire this damn thing.. And yes, I'm slow with these things..
  9. #19
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by MatrixPC
    You don't need VB.NET to read the source files. They are ASCII files and can be read with the text editor of your choice. There isn't much relatioship between this source and what you'd do in VB6. In VB6, the easiest thing to do is use the MSCOMM control. Just open the port, set the output lines, and enable events. When an event comes in, just check the status line values. Shouldn't be more than 10-20 lines of code.
    For a shutdown controller, you might just use the built-in UPS service in XP. It can be configured to simply monitor the serial status lines for low/high values. You'll have to figure out which lines it monitors for which things. I believe (but am just guessing) that it's CTS (battery low), CD(UPS on/off), and RI(Line / Battery). I could (and probably am) wrong about that.
  10. #20
    Mar 2004
    Redondo Beach, CA
    Here is a nicer schematic for those of you who like clean pictures.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. Girder vs MSComm, different input through serial, why?
    By InFix in forum Software & Software Development
    Last Post: 10-22-2002, 09:49 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
