Page 6 of 9 FirstFirst 123456789 LastLast
Results 51 to 60 of 85
Thread: Simply serial input circuit
  1. #51
    Newbie thasaint's Avatar
    Jul 2003
    new york
    well then that makes sense. i guess i wasn't thinking like that.
    thank you all for enlightening me.
    the flesh does not determine what is within.
    carputer is in begining status
  2. #52
    Jan 2003
    Ruston, LA
    If you are interested in discussing other solutions, please start a new thread.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #53
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    frodo, thinking of manufaturing these anytime in the future...could make money and that way i will feel safer with distributing these
    Of course since you will monopolize the disribution of this device, you can make a nice price for it
    I understand how it works...simple and nice thank you everyone!!! Now i need to perfectly understand how when the hand brake is not up, then the NC will not send a signal, thus, the pole will have no charge...so why do we need NO?Again i am not an engineer...trying to learn
    thanks
    DICE Los Angeles
  4. #54
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    You need a double throw relay to make sure the pole (attached to a serial input pin) always gets a valid RS232 level instead of floating. For many modern serial ports, it's possible you can float the input and it will still be detected as a low voltage (logic High).
  5. #55
    May 2004
    Hollywood
    Red face
    Quote Originally Posted by rando
    Ok so, in my case where I dont want people to be able to switch off the interlock...I can just do the following without the switch, am i right?
    I have not hooked up a interlock system yet, where is the positive and the negative of the handbrake (i am guesting I just splice the one wire that goes to the handbrake and the part that is attached to the metal is (-))? well here it is..
    DICE Los Angeles
  6. #56
    Mar 2004
    Redondo Beach, CA
    I'm not sure what you're asking. Your diagram is exactly the same as the one suggested in this thread (see post #20) assuming you hook your relay pole up to DSR. Frodo just posted a version using a switch instead of a relay -- for testing purposes only.
  7. #57
    May 2004
    Hollywood
    Nono, I was just looking for final approval of the design...frodo approved
    DICE Los Angeles
  8. #58
    Mar 2004
    Redondo Beach, CA
    ok, well like I said, your design is the same as the one in this thread which is the one that FP1.09 supports. Basically anything that can toggle the DSR line will work in FP1.09.
    BTW, I'm not sure what that diode is doing for you. If you meant to block kick-back from the coil, it should be in parallel with the coil pins.
  9. #59
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    Why do you need to short pin 6-4 when 6-7 isn't shorted? I've tested with just shorting and "unshorting" 6-7 to launch and shut down FrodoCam, and i didn't find any need for shorting 6-4?
  10. #60
    Mar 2004
    Redondo Beach, CA
    It guarantees that pin 6 is always at a valid RS232 level. Read the thread, it's been explained.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. Girder vs MSComm, different input through serial, why?
    By InFix in forum Software & Software Development
    Last Post: 10-22-2002, 09:49 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
