Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 85
Thread: Simply serial input circuit
  1. #61
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Maņana
    Why do you need to short pin 6-4 when 6-7 isn't shorted? I've tested with just shorting and "unshorting" 6-7 to launch and shut down FrodoCam, and i didn't find any need for shorting 6-4?
    To comply with the standard. Some ports will recognize 0 volts as logical
    low, some will not. This guarentees it works with all.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #62
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Technically those that recognize floating inputs (not the same as 0v), probably do so as a logic HIGH, not LOW. RS232 voltage levels are < -3V = High, > +3V = Low. Many modern ports pull their inputs down and thus produce a logic HIGH when floating and also extend the HIGH range to < 0V to be pseudo compatible with TTL signal levels (0v, 5v) -- albeit inverted.
  3. #63
    Maximum Bitrate GruvThang's Avatar
    Jul 2004
    Northern Virginia, USA
    so Frodo how close are you to having these listed in the store?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
  4. #64
  5. #65
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    all the kids guy, frodo Guess you love it
  6. #66
    Jan 2003
    Ruston, LA
    Well, I have to discuss that with Zip first
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #67
    Jul 2004
    Sweden
    zip?
  8. #68
    Jan 2003
    Ruston, LA
    zip?
    Ziplock, the owner...
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #69
    Jul 2004
    Sweden
    aha, okay :P Now, that was kind of embarrasing...
  10. #70
    Variable Bitrate M^ck^y's Avatar
    Aug 2004
    Melbourne
    I am also very keen on not getting into troubles with the Australian law here. I just tried this schematic, but without the relay for testing purpose and it worked. Whenever I shorted 4 & 6, it launched the Frodocam and then off as soon as I unshorted them. It worked as well for the video part but the video didn't show itself automatically. I had to touch the Vis Button untill the video shows. Am I doing something wrong?
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. Girder vs MSComm, different input through serial, why?
    By InFix in forum Software & Software Development
    Last Post: 10-22-2002, 09:49 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
