Page 9 of 9 FirstFirst 123456789
Results 81 to 85 of 85
Thread: Simply serial input circuit
  1. #81
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Sorry to revive this, but i just found this through a search and I remember the discussion... frodo has the unit come around? I remember seeing something, but cant find it right now...
    Or if someone else wants to tip in, I want a unit that can do movement lockout, rear cam trigger, maybe some realys and such...
    Thansk!
  2. #82
    Jun 2002
    Malaysia
    tag
  3. #83
    May 2005
    UK NorthWest
    Anyone thought of using a MAX232 or Analog IC in place of the relay's?
  4. #84
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    The relay is for isolation. The Max232 does ttl/rs232 level conversion. How would you use it in place of the relay?
  5. #85
    Tainted Love Cris's Avatar
    Romania
    This is a really cool device! I've been reading this thread, and my question would be why not disable video, dvd and others directly from Windows (I don't know if that's actually possible) instead from a front end.
    Or, to make it legal, let's say you disable everything needed from Frodo player, but then, would it be possible that as long as the handbrake is not turned on, you can only run Frodoplayer?
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  3. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  4. Girder vs MSComm, different input through serial, why?
    By InFix in forum Software & Software Development
    Last Post: 10-22-2002, 09:49 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
