Results 1 to 9 of 9
Thread: stepper or servo control
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I want to have my monitor rotate down 90║ when I turn on ign. and rotate up 90║ when I turn the ign. off. I want to keep this simple, no eloborate software for adjustment, just ign. control.
    Since the rotation is only 90║, gear reduction on a regular DC motor would be extreme, so my question is how do I control a stepper or servo for this task?
    Also any recomendatons on hardware? Rember this is a touch screen so I need enough torque to hold it in place while using touch screen.
    Mar 2004
    Vancouver, BC, Canada
    Some sites you may want to look at for servo/stepper stuff:
    www.lynxmotion.com
    www.hvwtech.com
    www.robotcombat.com/store.html
    Particularily:
    http://www.lynxmotion.com/Category.aspx?CategoryID=52
    http://www.lynxmotion.com/Category.aspx?CategoryID=38
    If you go with servos you may want a large scale or mega servo.
    May 2003
    Atlanta, Ga.
    Quote Originally Posted by archimense
    www.lynxmotion.com
    www.hvwtech.com
    Particularily:
    Thanks, I'll check thos now.
    Jun 2003
    Memphis - TN
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    May 2003
    Atlanta, Ga.
    www.lynxmotion.com
    www.hvwtech.com
    Particularily:
    Looks like the servo controller needs to be connected to pc.
    I dont know that much about servos, but I know the speed and position are controlled by a pulse. So is there a way to control 1 servo without it being connected to my pc (no spare port). I need it to slowly (about 3-4 sec.) rotate 90║ when I turn on ign. and rotate back on ign. off.
    May 2003
    Atlanta, Ga.
    *bump*
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    try talking to a local hobby shop, they use servos a lot in remote controlled vehicles.
    Mar 2004
    Quote Originally Posted by more mods
    Check out the Servo Playback module on this page:
    http://www.robotstore.com/catalog/list.asp?cid=17
    That is the closest all in one you may find. Otherwise you could get a Basic Stamp chip or PIC and write a little code for them to control the servo the way you want.
    www.parallax.com
    May 2003
    Atlanta, Ga.
    That is the closest all in one you may find. Otherwise you could get a Basic and write a little code for them to control the servo the way you want.
    www.parallax.com
    I saw that, but it records 4min. and plays that back, so it will not work.
    I know nothing about "Stamp chip or PIC" or writing code.
    This ideas seems simple enough, basically same as power antenna, key on monitor down, key off monitor up. But I need it to be rigid while down, so that when I touch the screen it doesnt move. That's the reason I want to use a servo or stepper.
  1. My LPT Relay Control Software
    By wizardPC in forum Software & Software Development
    Last Post: 02-13-2005, 12:10 PM
  2. cd changer control to control the pc
    By babas151 in forum General Hardware Discussion
    Last Post: 10-25-2004, 11:21 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. Servo vs Stepper Motors vs simple hobby motors...
    By chiark in forum General Hardware Discussion
    Last Post: 06-15-2003, 11:04 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
