Results 1 to 4 of 4
Thread: No VGA Signal...
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    No VGA Signal...
    So I start up my carputer the other day, and I get a "no vga signal" on the lilliput, I
    I check all the extension connections, and one of them is loose, so i reconnect it..
    I start back up and still no signal,
    THen I take the lilliput inside and try it on my home computer, it works..
    Then I bring a regular monitor down to my carputer, and It also gets no signal.....
    So in conclusion, The mother board is not putting out a proper vga signal (everything boots up and is fine elsewise as far as I know on the MB)...
    What are the possible causes of this? (loose connection?)
    Can I fix this without buying an entirely new motherboard..?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    reset your cmos, i think there is a setting that disables vga and only runs the TV out
    Feb 2004
    Charlotte, NC
    ok, so i reset the cmos (changed the 3 pin connector next to the battery, and then back,right?)
    Now I get a VGA Signal .. but only the very first boot up screen shows
    It shows a big graphical "Syntax"(name of motherboard) and then goes blank, and that's all I see.
    What should i do?
    Nov 2004
    New York
    I had a similar problem when I connected a usb device that the usb contoller was not properly installed. When I was stuck in that black screen, if i disconnected the usb device, windows will load up fully. Check your hardware device manager to see if the usb controller does not have an exclamation next to it. If so, just reinstall the drivers. Hope this helps
  1. Cleaning VGA video signal
    By Destin in forum General Hardware Discussion
    Last Post: 12-28-2006, 11:17 PM
  2. lilliput screen no vga signal
    By infinkc in forum LCD/Display
    Last Post: 03-13-2004, 01:22 AM
  3. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
  4. Amplifying the VGA signal...
    By WakeAndSno in forum General Hardware Discussion
    Last Post: 11-20-2001, 09:48 AM
  5. LCD signal differences - composite vs. VGA
    By laxrox in forum LCD/Display
    Last Post: 11-12-2001, 03:15 PM
