Autoruns
For all you tweaking startup times...
Autoruns
http://www.sysinternals.com/ntw2k/fr...autoruns.shtml
Simply run Autoruns and it shows you the currently configured auto-start applications as well as the full list of Registry and file system locations available for auto-start configuration.
To view the properties of an executable configured to run automatically, select it and use the Properties menu item or toolbar button.
Navigate to the Registry or file system location displayed or the configuration of an auto-start item by selecting the item and using the Jump menu item or toolbar button.
To disable an auto-start entry uncheck its check box. To delete an auto-start configuration entry use the Delete menu item or toolbar button.
Have fun
Drew
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
