Results 1 to 10 of 10
Thread: Look at this case
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Look at this case
    I can't believe that I actually could see this TINY CASE! I wonder if there is anyone who has used this yet? It seems awesome. It is Casetronic Travla C134 and it is barely larger than a full size CD-ROM as it seems. I was reading that you need special 'low profile' DDR though.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Constant Bitrate b_nom's Avatar
    Houston, TX
    dude, use I just did and found like 170 posts about that case, it's been around for a while.
    BTW I searched just for "c134", probably can narrow search a bit more, but just trying to make a point. Don't do like all n00bs and use the
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Jun 2004
    Buena Park, CA
    Well I have ed and ed until my thumbs flew off, and everything in these searches discussed integrating into home theater systems. Oh well, I will buy it and then attempt to play with it
    EPIA MII-12000
    Hitachi 60GB
    Carnetix P1260
    Variable Bitrate NoPistonPC's Avatar
    Boston
    Quote Originally Posted by choyak
    luckily you still have eight more fingers to some more...
    j/k, it's a great case to use for a carputer.
    1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Here I'll help.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Mine is smaller.
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Rob Withey
    Mine is smaller.
    You should probably keep that fact to yourself.
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by rando
    Size doesn't matter, it's what you do with it that counts.
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    Here is pretty muhc the same case
    These cases are all over the place..even at frys electronics...called mini itx case...her is mine and it is brutally modifyed
    DICE Los Angeles
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Mine's gonna be half of that if I disconnect the PCMCIA slots
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  1. Replies: 97
    Last Post: 09-18-2006, 02:56 PM
  2. Looking for double DIN 7 x 4 epia case
    By pieter3d in forum Newbie
    Last Post: 06-22-2004, 06:34 PM
  3. To case or not to case?
    By dummptyhummpty in forum General Hardware Discussion
    Last Post: 04-08-2004, 07:19 PM
  4. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  5. Mounting the case
    By TheFly in forum General Hardware Discussion
    Last Post: 05-05-2002, 04:11 PM
