Results 1 to 5 of 5
Thread: Having issues with Epia M motherboard
    May 2004
    I havnt installed my pc into my car yet but i noticed that when the pc is off the usb and ps2 devices are still powered, havnt found anything on this so i have to ask :P does anyone know how or even if u can turn off this "feature" off so it wont drain my battery w/o putting another switch on the line to completely cut the power?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Power your USB hub from you opus/ITPS so that when it powers dow it turns off the hub too.
    May 2004
    i dont have a hub, all the devices are pluged stright into the motherboard, and the ps2 devices remain on too, so its not just the usb
    Constant Bitrate b_nom's Avatar
    Houston, TX
    that's a "feature" that VIA won't fix . do a to see hoew people have fixed this. some have used the 5v line coming straight from the PS and cut in the middle of the one coming form the connector, so that when the PS shuts off, so do the devices.
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    May 2004
    I have the opus 90w and the directions state that even standby power can be shut off completely if you set a jumper on the board.
  1. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  2. WD HD with Epia Motherboard
    By h22lude in forum General Hardware Discussion
    Last Post: 02-10-2004, 12:48 PM
  3. Lilliput 7" VGA and EPIA M9000 issues...
    By heat in forum LCD/Display
    Last Post: 01-15-2004, 04:57 PM
  4. FS/FT: Via EPIA 800 Mini-ITX motherboard including 128mb PC100!
    By Ashlawn Kemling in forum Classified Archive
    Last Post: 12-19-2003, 02:54 AM
  5. Check out this epia motherboard!
    By Mitokondria in forum Off Topic
    Last Post: 05-08-2003, 09:16 AM
