Easy, Write a small app in vb for example and run it as an external application from within what ever frontend player you use,
within visual basic create a form and use a comm control component to allow port access say on comm 1 (9 pin serial port), and throw command strings at it to get it do what you want while having the climate control hardware connected to external hardware your design possibly D-A's etc digital to analouge converters. there are apps here on the forum i believe wizard pc has made a good app that works with a relay card readily avliable, however this will only turn things on and off, if you want to be more controlling with the climate conrolled system you'll need to i/o comms with the pc and i wouldve said either a dedicated i/o card plus heavy programming, or pic device controlling the climate control that is connected via the comms on the pc
LinkBack URL
About LinkBacks
but nothing special found about replacing A/C with a computer interface!!!
