Results 1 to 4 of 4
Thread: Slim Panasonic DVD & a HD thru USB Hub?
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    The motherboard that I am thinking of using for my install only has two USB ports on it. My intent is to have two USB hubs installed. One for 1.1 devices and another for 2.0 devices. I'm going to have two harddrives in the car. One drive is gonna be on the IDE channel and the other is gonna be in a removeable rack in the front.
    Can I run the Panasonic Slim DVD and a 7200 WD harddrive through the USB2.0 hub?
    USB2.0 is supposed to run up to 480MB/s (or 400MB/s. Can't remember which is FireWire and which is USB). ATA133 is supposed to be able to do up to 133MB/s. So, in theory, I can run 3 ATA133 devices through a USB2.0 connection.
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Well you could connect more than 3 ATA133 because they are accessed not simultaneously.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    USB2 is 480Mbits/sec, I believe. ATA133 is 133MBytes/sec (1064Mbits). ATA133 is faster than USB2. Even 5400rpm drives are much slower when connected to USB2.
    Mar 2002
    Austin, Texas
    So I would be better off trying to incorporate the removeable rack into the trunk where it would be able to run off the IDE?
    Derek
  1. IDE to USB?? or USB slim slot load dvd drive
    By mercury in forum General Hardware Discussion
    Last Post: 04-07-2008, 12:50 PM
  2. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  3. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  4. OPUS to External DVD Drive & USB Hub
    By Rith in forum Newbie
    Last Post: 06-01-2004, 04:45 PM
  5. Buslink slim usb 2.0 dvd rom
    By amrit50 in forum General Hardware Discussion
    Last Post: 10-10-2003, 04:38 PM
