Results 1 to 7 of 7
Thread: Remote PC Power Switch
    Low Bitrate Terran's Avatar
    Jun 2004
    So Cal
    Has anyone used one of these:
    From the site: "REMOTE CONTROL! Now you can remotely power up your PC at a distance with the Ignition 1 PC Power Switch Cable with Wired Remote. No need to reach down and power up your PC, this sleek gadget enables you to turn on/off your PC at a touch of a button from up to 6 feet away. It's equipped with a power button, reset button, LEDs, 80-inch cord, and attaches easily to your motherboard front panel power pins."
    Cost is $10.99 plus shipping. Worth the money or make your own?
    Why is it drug addicts and computer afficionados are both called users?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    $10.99 plus shipping?? Definetely make your own. It may cost you like $2, if you don't have a ball of wire and a switch.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    ya, definitely make your own
    just extend the current power button
    i thought this was going to be about a REAL remote pc startup (ie no wire)
    im looking to do this and my solution was to use my alarm system and setup a button on my remote to feed 12v to my opus psu for the accessory line
    Newbie lucho's Avatar
    May 2004
    I bought a momentary switch from the shack, soldered RJ45 to it, then took the ends off of an old case, soldered those to the RJ45 also. Then just plugged it in the board and I got my power button. I also added two LEDs, why not, RJ45 has 4 pairs, used 1 pair for power, another for Harddrive LEd and one for power LED. All under 8 bucks. Works good. That one seems short if you have your PC in the back of the car, especially after routing the cable to hide it.
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    Either you can use remote engine start from the alam system or just assign one channel from the alarm to power up the PC!!!! And the power off the PC!!!
    The best choice in my opinion..
    And if u use an OPUS the ignition key feature will work *** well!!!
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    i was interested in getting that remote pc switch for $10, anyone wanna sell theirs or know a place to get it that actually has it in stock? thanks guys!
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    Wow, that's's not really a remote.
    I saw this thing at pep boys for 20 bucks that will give 12v to something when you press the remote (actually a remote, unlike this retarded thing)...there's got to be a way to hook it up through a relay to turn on the pc. Any thoughts?
  1. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  2. How to switch on the pc with the key?
    By windalo in forum Power Supplies
    Last Post: 06-08-2004, 11:38 PM
  3. Adding remote to power locks
    By Charliey in forum General Hardware Discussion
    Last Post: 01-19-2003, 02:15 PM
  4. inverter delay to power on pc prob
    By felix99 in forum Power Supplies
    Last Post: 06-26-2002, 03:40 AM
  5. remote turn on lead from headunit to power up PC
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-27-2000, 03:13 PM
