Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 104 of 104
Thread: WARNING! Damage to your hard drives.
  1. #101
    Low Bitrate TheKurbster's Avatar
    Sep 2003
    Man, maybe i should knock on wood. Sorry bout all u guys having problems, but i never had a problem yet. So far I've had my desktop harddrive in there for bout 2 months, without no shocks or any sort of shock absortments. if u's like I could post up exactly how i have my system hooked up. Maybe it would give people an idea.
  2. #102
    May 2004
    Texas
    i have been running a shuttle xpc w/a 5.25 120g maxtor drive in the stock position with no problems for 5 months and my car is lowered and has stiff suspension
  3. #103
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by TheKurbster
    Don't get the wrong impression. We have several examples of desktop drives dealing with a car wreck while being used...
    They do not fail easily. Mine has been in several wrecks (one totaled my truck) the drive is just fine after more than 4 years of service and being installed in 3 cars.
    TruckinMP3
    Read the FAQ!
  4. #104
    A Brit in Las Vegas
    Quote Originally Posted by deadweasel
    I have to disagree on one point about your mounting advice, but it's conditional. If the drive IS going to be doing some writing, then yes, by all means mount that sucker horizontally. However, if the only thing it's going to be writing is to the swapfile, I usually say go vertical, the reason being that although the drives are designed to withstand a high level of shock, a single case of the drive hitting the platter could be disastrous for the drive altogether. There is a cushion of air generated by the spinning platters, but that effect is completely spoiled if the head hits the disc itself, and there's no guarantee the coating used on the platters will be sufficient to save them in such an event.
    Personally, I would rather risk a screwy pagefile, which would be rebuilt on reboot anyhow, then a toasted drive. Either way, if the car has shocks, and if you don't live in the Outback, I'm quite sure a hard drive hasn't much to fear being mounted in either direction.
    The advice wasn't mine but came direct from a hardware developer at Seagate. The shock required to bring a head in contact with a platter on a MODERN hard drive is huge - the force required rises exponentially the closer the head gets to the platter. The force required to cause a write error when the force is applied parallel to the platter is much smaller.
    However, most drives should survive in either position in most vehicles - it's just that the 'risk' is higher when mounted vertically.
    Steve
    RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
    Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
    Webmaster for the European Ford Scorpio Site
  1. How many hard drives?
    By rdc_3200 in forum General Hardware Discussion
    Last Post: 06-26-2004, 11:09 PM
  2. Laptop hard drives
    By djmickyg in forum General Hardware Discussion
    Last Post: 04-19-2004, 01:57 AM
  3. For Truck PC: Use 2 old hard drives or 1 new one?
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 11-11-2002, 11:26 PM
  4. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 09:50 PM
  5. 2 hard drives in 2 years...
    By nester in forum Off Topic
    Last Post: 07-30-2001, 11:44 AM
