Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 104
Thread: WARNING! Damage to your hard drives.
  1. #11
    Newbie 14500rpm's Avatar
    Jan 2004
    North Kent, England
    Quote Originally Posted by Yuriy
    Will it help to wrap it into this stuff?
    The hard drive heats up pretty good - could overheating be a factor?
    After all, it sits in the enclosure under the seat and there is only one fan which doesn't cool the hard drive, only its power supply unit.
    I assume you are talking about a desktop hard drive? If so I doubt that heat is an issue here, more the additional shocks the hard drive gets from being in a car - its a pretty unfriendly enviroment in there and they aren't really meant to be moved around a whole lot.
    You could try mounting it on rubber or something but I don't see it as any kind of solution. Laptop hard drive's are designed to take some impact so are a far better bet in a car IMHO, although you do have to pay for this additional protection.
    Could you try returning the drive if its new?
  2. #12
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Are you sure that the drive you have was DOA (Damaged On Arrival)?
    Hard drives (and other computer parts), like everything, can sometimes come bad from the factory. Maybe the little movement it went through was enough to just prompt the errors to appear more than before.
    I've been using a 3.5" Seagate Barracuda drive for about 6 months now, with no problems at all.
    I did however have a couple of problems with a Maxtor drive, one of the newer FBD (Fluid Bearing Drives) ones. It wouldn't work properly in the car during the winter. Moved it inside, and put the Seagate in the car, and have had no problems with either since.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  3. #13
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    It could be DOA. But I didn't experience any skipping during first few days of operation.
    I will do a throughout surface check this time and then we'll see if this happens again.
    After doing the incomplete surface check, skipping almost stopped.
    It's a good thing, because now I know the source of the problem.
    If you're saying that heat isn't an issue, I will most likely wrap the enclosure in plastic "bubbles" - they are great shock absorbands and I have a sheet of just the right size.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  4. #14
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    I've never had a problem myself (in over a year) - and that's including accidentally driving over a brick while the HDD was spinning. That's in an MR2 which had pretty hard suspension and now a Ford Focus with sports suspension, driving daily on harsh British country roads with no concern for the HDD!
    You can usually find the maximum operating shock the drive will support on the manufacturer's web site - yes 2.5's generally are more tolerant to shock.
    Mine isn't mounted in anything special, it's screwed as normal to the case chassis. The only different is the drive is mounted vertically, so the spindle is facing the same direction as the wheels.
    Other people have also added rubberised mounts to absorb some of the shock but even that could be overkill as long as it is mounted in a way to minimise the chance of a head crash.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  5. #15
    Jan 2004
    North Kent, England
    I wouldn't go as far as to say heat isn't an issue for a HD, but in this instance I think vibration is more likely to be the culprit - although as Confused points out a bad drive is a distinct possibility.
    If the drive is new I would definitely return it, I wouldn't advise covering it in bubble wrap though as this could make heat an issue. Modern HD's can get pretty warm under load, instead try mounting it as advised by stevieg - UK roads can be pretty poor and if he's had good results with it mounted vertically with the spindle facing the same way as the wheels then it should work for you too. Good luck!
    CarPC Progress: Glacial
    Currently: Scavenging for bits and hatching plans
    Got: Car, Dell CSx P3-500 laptop, docking station, USB2 PCI card, USB extension cable, USB2 hub, VGA extension cable.
    Need: Screen.
  6. #16
    Jun 2004
    Seattle
    Thanks, that should work
    I tried calling support, they told me that if the drive works they can't exchange it.
    They suggested running full surface scan in DOS, and that's what I'm doing now.
    It's a lot faster than Windows ScanDisk and I can see visual progress.
    Here's a picture of my HD's surface after 1/3 of the bad clusters were identified.
    I will put another picture once I make a full scan to give you an idea of the damage:
  7. #17
    Jun 2004
    Seattle
    So, just to make sure, by "facing wheels", which one do you mean?
    #1
    #2
    #3
    I'm assuming it's either #2 or #1, right?
  8. #18
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by stevieg
    Same here, only less time ( 6 months ) , harder suspension ( Pickup 4x4 ) and of course, worse roads ;( .
    Try first replacing drive and chose a better mounting position.
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  9. #19
    FLAC Mastero's Avatar
    Aug 2001
    India
    Yuriy ... Dont bother with the surface scan... you shall Just waste time and all you will get is marked Bad sectors, wont solve your problem.
    Do a low level format that will clear your bad sectors and get the HDD back to new state. You can find the software at the manufacturers web site..
    From my experience i have learnt 7200 RPM Hdd is not god for the car.. get a 5400 RPM works better with bumps.
    SEAGATE ... GOOD
    WESTERN DIGITAL ...... OK
    SAMSUNG .... BAD
    Cheers
    Mastero
  10. #20
    Aug 2003
    Warwickshire, UK
    #1 in theory is the worst. #2 is how mine is mounted and #3 isn't much different to #2 - as we're trying to make sure the drive heads aren't jilted in the direction of the plater surfaces.
    Regarding the supplier not replacing the disk - if you drove only a few miles I doubt that damaged it. I have on occasion driven around with the HDD in position #1 and had no damage - though I know if I did hit a big pothole I'd prolly have a head crash.
    There will probably be a certain bad-block threshold that would allow them to send back as DOA - if it can't even play MP3s properly due to errors then it's not working - it's not fit for purpose and they don't have a leg to stand on.
    Here's an idea - if they reckon it is OK then surely they won't mind swapping it and re-selling it.
    By the way, i'm using a 5400 Maxtor 30GB - Maybe 5400 does make a difference?
  1. How many hard drives?
    By rdc_3200 in forum General Hardware Discussion
    Last Post: 06-26-2004, 10:09 PM
  2. Laptop hard drives
    By djmickyg in forum General Hardware Discussion
    Last Post: 04-19-2004, 12:57 AM
  3. For Truck PC: Use 2 old hard drives or 1 new one?
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 11-11-2002, 10:26 PM
  4. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 08:50 PM
  5. 2 hard drives in 2 years...
    By nester in forum Off Topic
    Last Post: 07-30-2001, 10:44 AM
