Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 104
Thread: WARNING! Damage to your hard drives.
  1. #21
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by Yuriy
    I'm assuming it's either #2 or #1, right?
    I wouldn't place the drive in position 1, thats when the heads could crash with bumps. You would be much better off placing the drive in position 2 or 3.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  2. #22
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by Quattro-A4
    Snap
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  3. #23
    Variable Bitrate 4u2n's Avatar
    May 2004
    Denmark
    The best way to place the disk is number #2
    I have see many big disk system and the disk is in vertical as number 2
    and best disk to use in car 2.5 inch
    Cheers charlie
    So, just to make sure, by "facing wheels", which one do you mean?
    #1
    #2
    #3
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
  4. #24
    Newbie 14500rpm's Avatar
    Jan 2004
    North Kent, England
    #2
    #3
    I would say #2 or #3, most shocks the HD will take in a car are going to be in the vertical plane (pot holes and so on). I imagine you'd want a situation where the force causes the read/write arm in the HD to move across the platters (like a record player does when its playing - remember those ) rather than have it hit the platters (like a record player would if you just dropped the needle onto the record). Don't know if I'm (a) correct or (b) explaining myself very well
    CarPC Progress: Glacial
    Currently: Scavenging for bits and hatching plans
    Got: Car, Dell CSx P3-500 laptop, docking station, USB2 PCI card, USB extension cable, USB2 hub, VGA extension cable.
    Need: Screen.
  5. #25
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by 14500rpm
    Yeah, definately agree with you - exactly the same theory as mine. You don't want the head to 'scratch' the delicate magnetic surface of the disk - therefore by mounting it in #2/#3 it shouldn't (unless you spin off a corner and wrap your car's side round a lamppost
  6. #26
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    hi,
    Mine is close to the #3, I just have the IDE connector to the bottom. Thought that if the hit is to strong I prefer that the arm goes to is resting position instead of the centre of the platters. But not sure if makes a difference.
    But also a Seagate 5400. Is this a pattern or is just that these drives are cheap
    Brave
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  7. #27
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Just to be controversial, mine is in position #1. It's been like that for 4 1/2 years. It's a 2.5" drive mounted on rubber grommits, and my cars suspension is quite hard. I'm still on the same drive as I started out with, a 6.5Gb Hitachi.
  8. #28
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    #1 is what I also have on my 2.5" one.
    Thanks for all the replies! I'll do a full surface check and then a low-level format to be completely confident before putting my mp3s on the drive. Then I'll wrap the enclosure in "bubble plastic" and put it into pos. #2. That should do the trick.. I hope.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  9. #29
    Dec 2003
    New York
    I don't think you should wrap the drive in bubble plastic for the reason stated already, heat. You might want to use rubber stands, this may help reduce some of the vibration.
    Installed
  10. #30
    Sep 2003
    Virginia
    Quote Originally Posted by Bravellir
    Some drives park at the center of the platter.
    There should be a maximum acceptable limit for bad sectors, 12MB should be well beyond that limit. I would insist on it being replaced.
    As far as low level formatting, in my experience this isn't very helpful. If the sectors are seen as bad, they will be removed from the table and 'extra' sectors put into use to replace them, but there aren't that many extras, so you will still have bad sectors marked. I have seen low level formats mark bad sectors as good again, then later have problems and scandisk finds them bad again.
    I agree with the others that you should not wrap the drive in bubble wrap. I've seen heat kill a lot of drives.
  1. How many hard drives?
    By rdc_3200 in forum General Hardware Discussion
    Last Post: 06-26-2004, 11:09 PM
  2. Laptop hard drives
    By djmickyg in forum General Hardware Discussion
    Last Post: 04-19-2004, 01:57 AM
  3. For Truck PC: Use 2 old hard drives or 1 new one?
    By prerunnerv6 in forum General Hardware Discussion
    Last Post: 11-11-2002, 11:26 PM
  4. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 09:50 PM
  5. 2 hard drives in 2 years...
    By nester in forum Off Topic
    Last Post: 07-30-2001, 11:44 AM
