Results 1 to 3 of 3
Thread: damn lilput noise
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    damn lilput noise
    i did a pratice run for my carpc, had the computer runing from mains from the house and the lilput runing off the ciggertte lighter but I get altenator whine when i turn my liliput on (while my car is on), i turn it off and it goes away. Also lines shoot scross the screen. would powering it from the battery through a 12v regulator help?
    CarPC status: iPod, 3,456,217 songs so **** you
    Variable Bitrate no1knows's Avatar
    Feb 2004
    Guildford, Surrey, UK
    use the egg that comes with the lilliput, no point in using an inverter to just go back down to 12v in the end. Alternators will alwasy create noise, AC is far more likely to induce in signal cables.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    there's some identical posts about this - have a
    The lilliput does come with a small regulator on the cig-lighter lead however your problems are more than likely due to grounding issues.
    basically this means that the 'ground' base level voltage from your Car PC is slightly different to the 'ground' level voltage on the Lilliput, and due to the sensitivity of AV equipment it's very pronouced.
    So you also need to make sure that your ground point is good, and that the ground for the Car PC is the shortest route to ground. If it isn't then the grounding on the VGA cable could in theory end up the main ground for you car pc.
    There's a good sticky on this in the audio section that will help on this.
    Ford Focus MP3 : Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
  1. Noise on audio from laptop
    By pip in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-24-2006, 08:09 PM
  2. Replies: 86
    Last Post: 04-04-2005, 04:57 PM
  3. Damn Noise
    By Freeman in forum General Hardware Discussion
    Last Post: 03-20-2004, 01:37 AM
  4. need some noise help
    By spyhunter in forum General MP3Car Discussion
    Last Post: 07-20-2003, 11:20 PM
  5. Power noise - the horror!!!
    By mtmsol in forum Power Supplies
    Last Post: 06-19-2001, 10:13 PM
