Results 1 to 8 of 8
Thread: Seperate VGA and S-Video with Audio
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    The title is a bit vague but here is my situation.
    I am thinking of purchasing a VIA Mini-ITX EPIA ME 6000 Fanless Motherboard. With a GPS mouse + software and I would also like to add a TV tuner/DVD Player to this.
    I believe it is possible to have one thing displayed on the VGA Port and another thing on the S-Video Port. (Multi Monitor support, extend the desktop in windows? anyone done this?)
    So would it be possible to have GPS/MP3 screen on the VGA Port and have the TV Tuner/DVD screen on the S-Video Port. So I can flick between each by changing the Input selector on the LCD. Or so another person could be watchign TV and another viewing the GPS.
    The Only problem I have is the fact that the tv tuner/dvd audio will be merged with the gps/mp3 audio. Is there any way to seperate these 2 audio streams?
    The Winfast DV2000 TV Tuner has 1 phone jack for audio out. Would it be possible to only have the TV Tuner card audio through that jack, and only have the GPS/MP3 audio through the USB Extigy?
    Also the Mini-ITX is capable to producing 6 channel audio, it might be possible to have the GPS/MP3 through channel 1+2, and the TV Tuner/DVD through channel 3+4.
    Anyone done anything like this?
    Or would i be better off getting a seperate DVD Player and TV Tuner?
    I imagine the processsing power required for this may be a bit over the top!
    [edit]
    Is it possible to get the MP3s to mute when the GPS Software announces a command like "Turn right"?
    And the Mini ITX Has a standard ATX Power connector right?
    [/edit]
    Thanks.
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Exo
    Exo is offline
    Newbie Exo's Avatar
    Jun 2004
    Leeds - UK
    Take a look at the following, not good news though
    EPIA M 10000, dual display
    For some better news try the following:
    Display features!!!!
    Thanks Exo yeah i had seen those and i was hoping for some good news . Ah well, looks like I will have to get a seperate TV Tuner and DVD Player to do that then! Also does anyone know if a Pentium 166 Mhz be able to run GPS and MP3s simultaneously, and is there any Australian GPS Software out there with voice guidance and that will automatically dip the music volume when explaining the direction? eg. *Music*->*Turn Left*->*Music
    Thanks.
    Fox Mulder
    2004 Toyota MR2
    Newbie 4.9 EF Futura's Avatar
    Jun 2004
    Adelaide, South Australia
    Quote Originally Posted by Fox_Mulder
    Thanks.
    Howdy Fox.
    Well there's a lot of questions there, most of which I cant answer. I can tell you a 166MHz Pentium will struggle to play Mp3 back and operate GPS at the same time. Ive got a 233mhz laptop and it struggles with mp3 alone at 44khz, 16bit stereo.
    Cant think of any ozi GPS software to do what you need. Try www.oziexplorer.com but I dont think you'll have much luck.
    Sorry to be the bearer of bad news!
    1995 Ford Falcon - All Australian Car with All American Horsepower!
    Athlon 1333Mhz, 256MB DDR, GeForce4 MX 440, 20GB HDD
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by 4.9 EF Futura
    Snip
    Snip
    4.9,
    You should be fine with that, I am using win2kpro and winamp as a player. I event boot to windows first. The CPU is a P200MMX no skipping at all.
    TruckinMP3
    Read the FAQ!
    Constant Bitrate b_nom's Avatar
    Houston, TX
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    I have a DXR3 mpeg decoder board in my Pentium III 1000MHz. It does the decoding for the DVD player and has a built in S-Video jack and 1/8" audio jack. When you set the card's software to use the S-Video jack, the picture does not appear on the monitor, and the sound is directed out the audio jack. Regular windows events and music playback would still go through the regular on board sound card.
    Also, (heh) I have a Radeon All-In-Wonder 8500DV (in my system at home). It has a feature called theater mode. When you play dvds it displays the video full screen on the S-Video output and again, regular windows on the VGA port. However there is only one audio out... at least I assume there is, I hooked it all up per the instructions.
    I know that winamp version 2.x had the ability to use multiple audio cards, not sure about 3 or 5. I once had a setup where one sound card was connected to my desktop speakers and system sounds where defaulted through it. And then I had a second sound card connected to my home theater system and Winamp was configured to use that one.
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    My old thinkpad P133 laptop with 40MB ram ran autoroute 2002/2003 and winamp for many years without any issues. I also ran girder to control both of them.
    I still have the laptop if you want it?
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
