Results 1 to 5 of 5
Thread: Fried mobo->ALIVE- Opus to blame
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    So begins the next saga of the Fried motherboard...common thread...
    So I pulled my mobo out of the car to put the new one in, I'd found an old pci video card and decided to throw it on the board and see if it brought it to life... and whatdyaknow,
    a ressurection.
    Turns out my mobo even works without the pci video car... it was the opus all along.
    So, now I need to find out what is wrong with my opus,
    With the symptoms i've had...
    Loss of VGA signal,
    Momentary Logo display and then a black screen,
    Normal Hardrive/System/Fan startup
    the Beep.......Beep-Beep....Beep
    What is wrong with my opus?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    did you test the voltages?
    Feb 2004
    Charlotte, NC
    ....okay, so i put everything back in my car....
    and it works....
    thanks for all the help,
    lets hope i dont run across whatever that was again..
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Well, what was beeping, the motherboard? If so, you can look those beep codes up. They will tell you what the problem was.
    Also, maybe remove and reseat your RAM sticks. Same for any PCI cards you might have. Double check your in car mounting to make sure there aren't any shorts. The screw holes in the motherboard are a common place for this to happen.
    Plug the Opus into another motherboard or get a voltmeter to check it out.
    Sep 2003
    Wilkes Barre, Pa
    Quote Originally Posted by cadence117
    and it works....
    More then likely it was a lose connection.. Well lets atleast hope thats all it was.. Good luck.
  1. Opus and BMW (e46)
    By captain_jim1 in forum Power Supplies
    Last Post: 01-21-2005, 12:46 AM
  2. Hot Hot OPUS!!
    By god_of_cpu in forum Power Supplies
    Last Post: 06-22-2004, 06:02 PM
  3. Replies: 8
    Last Post: 06-05-2004, 11:13 AM
  4. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 09:24 PM
  5. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
