Results 1 to 7 of 7
Thread: Connecting a CD/DVD player that's too far for IDE?
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I'm sorry if this has been brought up before, but I couldn't find the right key words to do a search.
    I haven't decided if I'll be using a CD/DVD 5 1/4" drive, or some kind of slim laptop drive. But in either case I think I will still have the same problem. I want to mount it in a location that will be to far away from the motherboard to use IDE. I'm estimating the distance to be 4 feet of cable. What are my economical options? The only thing I can come up with is a USB 2.0/IDE adaptor.
    Maximum Bitrate d_sellers1's Avatar
    Mar 2002
    Austin, Texas
    IDE cable are available at 36" (3 feet). Close, but I guess not close enough for your install. Take a look at this: HERE
    This is an IDE to USB2.0 adapter. It also comes with the 2.5" (laptop/slim drive) to 3.5" adapter. The power adapter can easily be modified for run off the computer's power (+5 & +12VDC). This is really the power needed for the drive.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
    Jun 2004
    I'm throwing in a Lacie Slim CD-R/DVD-ROM Combo drive in my system. They're $240AU (rrp is $149US). Reads just about anything and can burn on the go. Also powered off the USB/Firewire port so no stuffing with extra cables needed.
    Jun 2004
    Toronto, Canada
    I've also been thinking about shoving a drive in the center arm rest vertically. The issue with that is I would need a slot load drive. The only one that I know of around here is the Pioneer 16X DVD drive. I have the tray version in one of my PC's at home. I find it to be a very loud drive. It sounds like it's going to lift off any second. Does anyone know if Pioneer got the noise down on those drives in the last two years?
    Jun 2004
    I have one and it doesn't seem too noisy. Then again I really haven't used it too much, but the times I have it seemed to work really well.
    Jun 2004
    Toronto, Canada
    I notice it making a lot of noise when I insert a DVD. It spins up quite fast and then backs off a little, but you can still hear it. My new NEC DVD-DL burner is so quiet I can't even tell it's running. It's just a bit of an overkill to put in a car.
    May 2004
    Quote Originally Posted by The Grinch
    try the nero tool, it will slow down the speed the drive operates and makes it silent. i used one in a shuttle home entertainment system and set it to work like 8-12 speed for cds and it was silent, the dvd part is silent natively
  1. Mod an MP3-CD player to accept HDD
    By losttoy in forum General Hardware Discussion
    Last Post: 06-08-2004, 09:30 AM
  2. Replies: 2
    Last Post: 05-11-2004, 12:07 AM
  3. Aiwa vs. Pionner cd player
    By mp3stealth in forum General Hardware Discussion
    Last Post: 09-03-2003, 06:34 PM
  4. Slot load CD/DVD player?
    By Glyn in forum General Hardware Discussion
    Last Post: 07-16-2003, 11:38 PM
  5. rca is going to kick *** with this player ....
    By KING ZOMBIE in forum General MP3Car Discussion
    Last Post: 07-14-2000, 08:51 PM
