Results 1 to 10 of 13
Thread: please take a moment to help this noob....
    Jun 2004
    Jun 2004
    this may seem like a simple task but i am trying to extend the power supply cord for my radar detector, could yall help me out?
    what wire would be best to use?
    what is the best way to splice it back together?
    thank you for your time
    Jun 2004
    Under the radar
    You can get "barrel connectors" from any radio shack. All this requires is you to cut the cord, get another strand of wire and put them together. The barrel connector requires crimping.
    ---ORIG WIRE------>[BARREL]<---NEW WIRE--->[BARREL]<----ORIG WIRE-----
    AdamR
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    simple
    old.....x.....new.....x.....old
    x= tie together, crimp with a barrel....whatever
    DICE Los Angeles
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Quote Originally Posted by hxcsemu
    I typically piggy back things together. Splitting each wire in half ---< >-----
    and twisting one side with the other side and the the other side with the other side and then all together then tape!
    http://www.bulldogsecurity.com/pdf/M...1200_1200E.pdf
    Take a look at this site, it has some good ways how to make some connections on page 3 and 4.
    good luck!
    BossTone74
    Jun 2004
    ok thanks all, i had a pretty good idea but the people at radio shack didnt seem to know any more than i did, they said they have no "adapter extenders"
    any wire should work?
    special size or guage wiring?
    thanks again
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    Sep 2003
    Elgin, IL
    what kind of power connector is it? prob be easiest to go to radioshack and get the opposite matching male/female connector, solder your extension there and get another of the same connector you have already.
    another note. why do you need an extension? your radar detector shouldn't be totally out of reach of the cigarette lighter. another possibility you might awnt to consider is a hardwire.
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    You want to do it right? Do NOT use tape and those twist-on wirecaps. Do it the way the pros do. Either splice the halves of the wire together and cover the splices with shrink tubing (available at any Radio Shack), OR, use "butt splices" which are little barrels that the wire ends go into, and get crimped down to lock it all in place.
    This way, you don't risk a short from an unexpected exposed wire, and possibly blowing a fuse in a potentially important circuit. I've seen some vehicles where the gauges and the lighter were on the same circuit.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Jun 2004
    Seattle
    Or, you can do what real pro's do and solder the ends together.
  1. total noob... HELP PLEASE.
    By stub004 in forum Newbie
    Last Post: 06-11-2004, 08:44 AM
  2. Stupid NOOB question..
    By phatbimmer in forum MediaCar
    Last Post: 05-03-2004, 08:01 PM
  3. NooB question
    By ouikikazz in forum Newbie
    Last Post: 04-19-2004, 02:34 AM
  4. Replies: 2
    Last Post: 09-30-2003, 08:47 PM
  5. noob need help?
    By fast-shot in forum General Hardware Discussion
    Last Post: 08-21-2003, 07:05 AM
